Isobaric Subwoofer
Isobaric Subwoofer
I decided recently that my home cinema system could do with a nice subwoofer, and rather than buy something, I thought I'd build myself one...
NOTE: This is only a short explanation, there is far more info here - http://www.yourmissus.com/subwoofer/
Step 1Cutting
Cutting
Construction starts with measuring and cutting the MDF.
My design with its double skinned walls does require quite a few panels - 18 in fact, and to ensure we end up with a rigid and airtight box the cuts must be very accurate.
Ideally for this task you would use a tablesaw - we are looking to achieve accuracy of panels to better than 1mm.
This would take some doing (or at least a lot of plane work and sanding) with a handsaw or a circular saw.
This first stage of marking out and cutting is very important (and a little boring) but it cannot be rushed.
The end result really does depend on how accurate these panels are cut, so measure twice, cut once, take your time etc...
It will pay dividends later.
97 comments
1-40 of 97next »
Dec 18, 2009. 11:53 AMstuffman says:
Well done, I bet this thing weighs a ton!
May 23, 2009. 10:37 PMhack124x768 says:
Do you know anything about the sound output when wired in series or parallel? I built a planar isobaric box for my car (so many benefits... Stackable, protects the drivers, better sound quality...) and when I switched the wiring from 2 ohm to 8 ohm the output volume got much higher. Is that just an amp quirk or a property of these enclosures? Usually amps potential output goes up when you lower the resistance, from what I have read. Very confused here.
Aug 16, 2009. 1:31 AMDa Nugesta says:
ok so what will i get if i have 8 8ohm speaker wired in parallel (soz i am too thick to work it out!)
Aug 16, 2009. 10:16 AMDa Nugesta says:
ok thnx soo much you really helped me, the amplifier i need runs 6-16v DC and 4-16ohms i am making a mini 8 driver (18x18mm they re so small) line array, so heres a diagram correct me if i am wrong. A --Speaker1--Speaker3--Speaker5--Speaker7 M | | | | P --Speaker2--Speaker4--Speaker6--Speaker8 Thnx for replying so quickly. i will probably post an instructable when i get the speakers and start to make it! thanks again! :-)
Aug 16, 2009. 10:18 AMDa Nugesta says:
the lines next to 'M' are supposed to show each pair connected but when i posted the comment it got rid of all the unnessesary spaces >:-(
Jun 3, 2009. 12:20 AMhack124x768 says:
Hmm. I may have found a fluke then. With the speakers wired in phase or out, I still have more power in 8ohm (tried both polarities as I thought I might have forgotten which way I wired one of them). What caused me to switch in the first place was I noticed my sub volume didn't increase in a very even fashion with my midranges. At a low volume with it balanced, the subs would be overpowering at a high volume. With them balanced at a high volume, the subs would be inaudible at a low volume. I suppose I just have a retarded amp. From what I have heard, sound quality tends to be better at a higher impedance as well. Any thoughts on that?
Jun 4, 2009. 5:00 AMhack124x768 says:
It's a 2ohm 300watt rms mono amp. I'm hoping to replace it with a stereo one by a more reputable brand in the future though. My current one is a bazooka, and I'm looking at alpine and pioneer. I've got a pioneer driving my midranges, and it sounds amazing. The problem with running stereo amp, is I would still need to make the signal mono. I doubt the isobaric configuration would perform well with signal only going to one driver. Eg, bass drum on only the left channel.
May 5, 2009. 10:14 PMBMWalsh says:
Do you get port noise from that ruffled carpet on the inside of the port?
May 6, 2009. 7:49 PMBMWalsh says:
Lol, for me, a reasonable volume level is not nearly enough :-P
Oct 31, 2008. 12:27 PMKoil_1 says:
...That's not to mention being able to get into the cabinet to replace a blown or damaged driver... This is seriously important because if you can't replace the driver you gotta rebuild the whole project. Having worked in this field I've seen how hard it is to open one of these boxes after it's been completely sealed. It's difficult at best and usually renders the project as scrap due to breakage of the building material.
Oct 31, 2008. 12:21 PMKoil_1 says:
One could just as easily use a 90° bend available from most places that sell PVC fittings. It's what I do and it works well because of the uniformity of the curve. They usually cost less than $5. Preping the fittings isn't that hard either if you don't mind the cleaning chemicals and glue. Another added bonus to this is the flange on the end that can be used to further extend the port to match the harmonics of larger drivers.
Jun 20, 2008. 6:27 AM-Aj- says:
OHHH isobaric woofers are sweet hey. well looks cool anyway.<br/><br/>..do six order bandpass isobaric.haha wooww way to be getting complicated hey :P<br/><br/>ANyway...<br/><br/>best calc tool for speaker enclosures. and is also free to download (freeware)<br/><a rel="nofollow" href="http://www.linearteam.dk/default.aspx?pageid=winisdpro">WinISDPro</a><br/>and here for abit of a tutorial thing<br/><a rel="nofollow" href="http://www.the12volt.com/installbay/forum_posts.asp~TID~74558~PN~1">Guide: Using WinISD</a><br/>
Jun 5, 2008. 8:11 AMmanticore says:
That was a really great idea to mount the speakers like that and make them out of phase. I've been building car audio subwoofer enclosures for myself and friends for a few years now. Right now, I'm making a box for four 6x9s. I'll post it when I'm done. I think I may take your idea with two 6.5"s. They're component speakers, so a bandpass box doesn't really make much sense, but I love the concept. I'll give it a try. I really wish I had a nice router.... Gotta use the Dremmel for now.
May 27, 2008. 6:34 PMangelwill26 says:
I sooooo want that router system! lol
May 27, 2008. 5:04 AMFriggin Smift says:
"F"ing awesome man I have built some woofers myself and I gotta say your work is top notch
May 26, 2008. 9:16 AMHammyHavoc says:
I'm extremely impressed (: AND jealous :P Nice one mate
May 27, 2008. 5:55 AMHammyHavoc says:
Well, I think I might spend the next few days making my own, I'll post some pics in a few days to let you know how it turned out! Thanks
Apr 25, 2008. 7:36 AMSolitus3989 says:
Hi toastyboy. there have been alot of 'arguments' above about whether your design is a subwoofer or just a woofer and whether is it isobaric or non-isobaric... i just have one question and a comment. How much did the whole project cost? And my comment is your daughter is very cute and im glad you could involve her. it's a bit of inspiration to me when i tell me little brother that he's too young to help. thanks for the instructable. and i hope your wife doesn't mind the "loudspeaker component designed to reproduce only extremely low bass frequencies" (if i called it a subwoofer/woofer i may be proven wrong in a barrage of comments) too annoying.
Apr 26, 2008. 8:47 AMSolitus3989 says:
thanks. :-D that would be about $300 USD, but i know we have alot of those things lying around. im thinking of making a sub box for my car, and i am looking for designs. without the need to buy the drivers, this would be a cheap and easy design. :)
Apr 29, 2008. 7:11 PMslimguy379 says:
I did this type of thing just I used a separate amplifier to really get the bass pump'n and I also incorporated a batman logo in the front but 1st off great tutorial and 2nd congrats on one awesome sub woofer!! I should take mine out of retirement and put it in my "home theater"
Apr 25, 2008. 7:35 AMgggonzalez says:
Very nice. I have made about a dozen subwoofers, both for automotive and home use. Nice work and the finish looks good. I prefer sealed (bass quality)and simple ported designs (more oomph). Larger order subs are more complicated, but fun! Technically, most "Subs" today are "woofers", because the mostly reproduce SPL above 20 hz, but common usage of the term "Subwoofer" applies to anything that is designed for the lower bass frequencies (60hz and below or there abouts). Well done
Apr 21, 2008. 11:46 AMPunkguyta says:
Those are woofers not subwoofers....sigh..
1-40 of 97next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:toastyboy
I'm fairly mint most of the time I'm a firm advocate of treating people how you would like to be treated yourself. People are always nice to me, so it must work! Try it!
