NOTE: This is only a short explanation, there is far more info here - http://www.yourmissus.com/subwoofer/
Remove these ads by
Signing UpStep 1Cutting
My design with its double skinned walls does require quite a few panels - 18 in fact, and to ensure we end up with a rigid and airtight box the cuts must be very accurate.
Ideally for this task you would use a tablesaw - we are looking to achieve accuracy of panels to better than 1mm.
This would take some doing (or at least a lot of plane work and sanding) with a handsaw or a circular saw.
This first stage of marking out and cutting is very important (and a little boring) but it cannot be rushed.
The end result really does depend on how accurate these panels are cut, so measure twice, cut once, take your time etc...
It will pay dividends later.
Well at least 40-50kilos I would say.
Cheers
Dan
You see that connecting two 4ohm speakers in series will give you an 8 ohm impedance. Connecting the same two 4 ohm speakers in parallel will give a 2 ohm impedance. Since power is V2 / R reducing the impedance from 8 to 2 ohms will increase the power 4fold.
There is a caveat though.... (isn't there always!!) Most, but not all amps can drive a 2ohm impedance, because 2 ohms does take more current and therefore power some amplifiers will just cut out, especially at high volumes.
If it works for you though, and your amp isn't getting too hot, then you'll probably be ok...
I suspect what has happened in your case is that you have the polarity of one of the drivers wrong... You want the drivers moving in opposite directions, mabybe in your 2ohm (parallel config) you had them moving in the same direction and therefore cancelling each other out?.... If your speakers are set up like mine, then you'll need to connect them out of phase (i.e for a parallel config connect the +ve of one to the -ve of the other and the -ve of one to the +ve of the other) ... for a series config (8 ohm) then connect the two +ve terminals together and then connect the amp to the -ve terminals of the speakers.
Good luck and thanks for the comment
Parallel resistances/impedances are calculated by summing the reciprocals and then finding the reciprocal of that, so
= 1/(1/8 + 1/8 + 1/8 + 1/8 + 1/8 + 1/8 + 1/8 + 1/8)
Which is 1.
1 ohm is a very low impedance to present to an amplifier though, so you may have problems. You might be better off wiring in series parallel to give something more sensible - 4 pairs of speakers wired in series connected in parallel would give a more reasonable 4 ohms
Dan
Regarding the cost, I would say it came in at under £150. This breaks down as:
£80 for the drivers
£20 for the mdf
£10 for the carpet
£10 for the electrics
£10 for fixings, screws, bolts
£10 glues, silicone and fillers
£10 piping bits and bobs
If you had to buy all new it would cost more, but the prices above assume that you don't (say) have to buy a full £10 tub of glue and only use half of it etc...
The time element is far more expensive, I spent probably 100hours on this, even at £10 an hour that's a grand!!
...but I loved doing it.
I'm glad you enjoyed my "enclosure containing a pair of transducers designed to produce (relatively) low frequencies within the bounds of the human audiable spectrum" !! ;-)
-Dan
It does make for a nice small box, and if you have your drivers parameters then you can tailor the design to match.
Good luck!
