Ital Seedling Box
Published
Introduction: Ital Seedling Box
About: Hi am kabucho a designer and maker mostly enthusiastic with new eco-friendly design and generally improving the functionality of items
This is a seedling box made from up-cycled wood from some old chicken feeding troughs.
The essence was to come up with a simple solution of propagating seedlings without using plastic bags.
Step 1: Materials Needed for This Project
6x2" wooden planks
Plywood
3 inch nails
Palletes
Step 2: Tools Needed for This Project
Circular saw
Jig saw
Power drill
Hammer
Screwer(optional)
Step 3: Making the Side Planks
We made the initial grooves using a circular saw. This were later widened using a wide drill bit to expand them to allow the partitions enough room to slide in & out without play.
Step 4: Making Plywood Partitions & Assembling the Frame to Pallettes
The approach we used was to make one piece for the rows and another for the columns; this was then used to cut out the rest of the pieces.
The longer partition was 120 cm x 20 cm with 1 inch grooves 10 cm apart.
The shorter piece was 60 cm x 20 cm with 15 cm grooves 10 cm apart.
This can then be reproduced to fit the amount of boxes you want.
We used the 3 inch nails to join the frame to the pallette.
Step 5: Adding Our Soil & Seeds to the Box.
Our soil was prepared a while ago with organic manure I will be posting up that video soon.
After adding the soil to the boxes sprinkle some water and let the soil be moist overnight so as to plant seeds the next day.
We planted our tomatoes and this is how it looked after 2 weeks then after a month there were ready for transplanting.
Step 6: Transplanting to Farm
Once the seedlings are ready for transplant all you need to do is slide up the plywood partitions gently and your seedling blocks are ready to hit the farm.
A great tip is to avoid watering your plants a few hours before transplanting at least 24 hrs is ok.
All the best in your organic farming.
    • Stick It! Contest
      Stick It! Contest
    • Casting Contest
      Casting Contest
    Wonderful! I love the organic, back-to-nature feel of this project. Great creative use of recycled materials. And, you practice what I've always been taught, water sparingly before transplant, water generously after.
