Introduction: It's Possible to Use the Angle Grinder As a Chainsaw
Carrying on our tradition of our video sequel for angle grinders, this fourth time we transformed our grinder into another useful machine, a chain saw. Our primary aim for this transformation was experimental while the usefulness of the particular machine came second in our priorities.
Step 1: Metallic Plate
We first did this experiment for multiple reasons such as to see if the angle grinder could really work as a chain saw, whether the angle grinder is burdened, if it gets warm and if it can be used as a last resort in case of an emergency. Therefore, our work starts making a metallic plate, on which the angle grinder is adapted and stabilized when necessary. On this metallic plate, we placed a metallic rail taken from an arboricultural factory as well as the chain and the gear of the particular machine. The chain that we placed on the metallic plate is revolved on a high speed without derailing its way supported by the gear that revolves the angle grinder at the particular time. This metallic rail has the potential to move towards and backwards as a result to enable us to set how tight or loose we want our chain to be.
Then, we made a protective cover around the chain close to the parts that we place our hands in order to reduce any danger. Thus, without any special difficulty the angle grinder 4 is a fact!!!!
Step 2: Testing
After completing it and testing it, we got amazed by its performance as an electrical chain saw. Although, we consider that this was a transformation of a high risk. Also, we must say that using a bigger angle grinder, the performance will be dramatically increased. However, the advantage of this transformation is that none of the components is modified as a result they can be easily returned unchanged to their primary position, where they were placed at the chainsaw.
Step 3: Result
To sum up, this particular transformation costs very little money and it can work in many different cases having great results. Additionally, it is much lighter than the common gasoline powered chainsaws, much less noisy with a small angle grinder and this is obvious when it is used for many hours as its temperature increases.
41 Comments
I must say that this is extremely stupid. I believe in personal responsability all the way but no one should ever EVER use a chainsaw without kickback protection.
This is a neat idea and is executed well. A great Instructible. The people complaining need to realize that safety is like craftsmanship: it's not the result of what tools you possess, it's the result of how you use them. An off-the-shelf angle grinder is already more than capable of causing injury or death, depending on who's using it. But if you fully understand and remain alert to the potential hazards involved, you can safely use just about any kind of tool. Conversely, if you're careless, inattentive, or unskilled and overconfident, even the simplest tools can be dangerous.
Awesome!
I hope that you have great liability insurance. Posting instructions like this will get you sued, especially if it's a kid that gets hurt or killed.
only in countries that does not believe in personal responsibility....
I think should be entered into the new Darwin Award category.
If anyone is even thinking this is useful in their life, go and buy on Amazon the Remington RM1425 Limb N Trim 8 Amp 14- Inch Electric Chainsaw.
It's much cheaper than a trip to the hospital.
You know all you people bit-- and complain about his hack. Although I do not see anyone of you putting something up now or lately. What is it you only had one idea and it was a chainsaw and he beat you to it? I think it was a good hack and my saw works great, although mine is on a much larger grinder and I used an oilier from an old chainsaw and the teeth also. Nice hack Make it Extreme
k. So What ? Go Back to Mepos or Crete......Or Somewhere
Why not simply arm the angle grinder with a circular saw designed for it?
ГЕНЕАЛЬНО!!!
