3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Itty Bitty Vibrobot
Step 5Attach the motor to the battery
My motor was still sticky on one side, so I just stuck it to the top of the battery. I think it's double sided tape, which you could use if you need to, or maybe hot glue it.
Scuff up the bottom of the battery a little, I think it should help the solder and hot glue adhere. I used a file to mar the surface. Make sure you clean it afterwards with a little alcohol. I believe acetone will work better than rubbing alcohol, but use whatever you have around.
Your motor should have two wires coming out of it. Solder one wire to the bottom of the battery. I had trouble getting the solder to stick, so I reinforced it with a little electrical tape (which you can't see in the pictures).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:pepik
