Introduction: J-5290 Steering Wheel Puller From a Propane Tank
Had to pull off steering wheel on a 1958 AMC Rumbler, which requires J-5290 steering wheel puller. Not easy to find, so I had to make one. Found that threads on a propane tank are exactly what I needed to get this started.
Step 1: Materials and Tools
Here is all the parts you will need.
Propane Tank ( EMPTY!!! )
Large nut and bolt, I used half inch diameter.
And tools:
Hack saw
Step drill bit
Welding equipment
Wire-brush
Step 2: Making Your J-5290 Puller
Make sure you are working with an empty propane tank, Cut off the neck of the tank, then bore out the inside of the neck. Careful not to damage the threads. Get your nut and bolt, weld the nut on to your threads. Clean and screw in your bolt.
Step 3: Application
Screw in your new puller in to the steering wheel with out the bolt. Get it nice and tight, then screw in the bolt. Tighten bolt till the steering wheel pops off. And your done.
If you like do vote. Thanks
Tools Contest
