Well, originally I wanted to make a Jacob's ladder which if you haven't already heard can be extremely dangerous! They are high voltage and if you complete the circuit with your finger it can be fatal...So, be very careful or just don't do it.
Most of the instructions I found used a transformer from a neon sign to generate high voltage and make the thing arc. I didn't want to go out and buy a transformer but I did have an old CRT (Cathode Ray Tube) monitor collecting dust. So, I decided to put it to good use and make a variation of a Jacob's Ladder.
Materials:
Monitor (CRT)
Wire (12 Gauge?)
Forks
Plastic Tube
Materials for Insulation
Remove these ads by
Signing UpStep 1SPLICE
The first thing you should do is put on some oven gloves, and get a piece of insulated wire. Attach one end of the wire to a ground pin (look around on the circuit boards etc.) and poke the other end of the wire under the suction cup until you hear a spark noise. Do it a few times until you are SUPER sure everything is discharged, and even then use a multimeter to check the voltages of everything your hands come near.
A flyback transformer in the monitor generates a few kV that is used to accelerate electrons in the CRT to hit the screen. There should be at least two large leads coming out of the transformer. One goes towards the suction cup near the front of the screen (thats the super high voltage one), another goes to the rear end of the tube (should be more or less 0v).
Cut the high voltage wire that goes to the suction cup, splice in a wire of your own and solder.
137
comments
Add Comment
| 1-40 of 137 | next » |
dog digger
says:
Turnip123
says:
DIY Dave
says:
Xellers
says:
puffyfluff
says:
Add Comment
