Jack-O-Laser of Doom
Ok, I thought the Laser Vortex was the coolest Halloween project yet. So this project pays homage to it. For my project, however I needed to make it small and portable to fit into a pumpkin. I also needed to make the laser and spinning mirror all 1 unit. So with a couple of mods, the Jack-o-Laser of Doom was born.
Step 1Make the Spinning Mirror
If you need to see how to make the mirror mount see mever's instructable,
steps 8 & 9 here-http://www.instructables.com/id/EXB5CA21JPET9K5F7Y this
is the genius of the project.
I Used a little 3 volt radio shack motor with the cog on it, and drilled a
hole in the bottle cap. Then I pressed the cap on the cog and put a lot of
super glue gel on it.
For my needs mounting the mirror at a 45 degree angle produced a vortex that
got too big in too short of a distance, so I just glued the mirror in the
bottle cap at a couple of degrees so I could get a tube of light.
30 comments
Oct 30, 2009. 12:42 PMtrinity5000 says:
if you look on the bottom of the curcuit board you will be able to see that there are metal film cut out and laid on to forn the different curcuits by looking three of the solder points should be conected togeter with one of these films all you have to do is put in a jumper wire conecting the three pins to the fourth completely bypassing the botton this will make the laser come on all the time when power is hooked up
Oct 11, 2009. 3:54 PMpaintballr says:
looks like a shoop da whoop
IMA FIRIN' MA LAZAR BLLLAAAAAAAAAAARGH!!!!!!!!!
Nov 1, 2008. 10:33 AMstrumbot says:
Freakin' Sweet!
Jun 5, 2008. 9:10 PMghost terance says:
cool
May 3, 2008. 3:53 PMwestin444 says:
try cooling the fog, or make a tunnel out of 1/4 pvc and sheets
Sep 13, 2007. 7:02 PMJollyrgr says:
An FYI: A keychain laser pointer can be found for $1.00 USD at dollar stores.
Oct 30, 2007. 1:03 PMalanL says:
would love some help finding one the laser lights. i've searched everywhere from 99 cent store to hardware stores. would a laser level work? great project. one more shopping day until halloween. thankx.'
Nov 8, 2007. 2:50 PMWhiternoise says:
eBay is pretty good - they have loads to pick from - mostly for knock down prices.
Nov 2, 2007. 9:52 PMHOU770 says:
This was the first spinner project I saw. Thanks for the inspiration. With additional ideas from the references, I put together a two mirror projector. Used with and without fog. I was afraid children would look into the beam, so I pointed it at the garage door. Not the best craftsmanship, but it worked. Keep up the good work.
Mar 2, 2007. 7:08 PMossumguywill says:
How many MWs must the laser be?
Oct 28, 2007. 7:02 AMel-pedro says:
most laser pointers are around 5mw, so almost any laser pointer will work
Oct 21, 2007. 5:30 PMemericanskater says:
what type of battery is the laser hooked up to?
Sep 21, 2007. 2:53 PMqdogg says:
A lazy man's way to this is to buy a gizmo called a "laser widow" (about $50) that will make all kinds of patterns & can be triggered w/music or sound. Stick on of those in there & add a couple tri-color changing LED's (I found them @ a dollar store) for eyes & you're done.
Sep 25, 2007. 2:24 PMARVash says:
Yes; but that would cost 50 dollars >>.. not 7 - 10 Nice alternative if you're not able to do these instructions though.
Sep 13, 2007. 8:12 PMDarth Robby says:
How much did this cost, I might do this.
Sep 17, 2007. 1:06 AMac1D says:
Nice i made one!
laser:1$
mirror:1$
motor(in a toy fan)1$
=3$ and work perfectly.
awesome, thanks you allot!
Sep 14, 2007. 5:06 PMDarth Robby says:
cool, about $11? that is a very good deal for such a cool thing!!!!
Aug 26, 2007. 8:11 PMDarkshot says:
OH-MY-FREAKING-GOSH!!!!! THATS THE COOLEST THING IVE EVER SAW MAN!!!!! AWSOME INSTRUCTABLE but wouldnt you get pumpkin in electric stuff? and it might electracute you...wow i cant spell but AWSOME JOB!
May 9, 2007. 2:25 PMVendigroth says:
you used lego, didn't you, for the platform that the mechanism's built on? that's pretty damn ingenious, actually
Nov 17, 2006. 7:00 PMd3struct says:
cool
Nov 1, 2006. 10:57 AMmasterhibb says:
On most of those little flat push-button switches with four contacts, two of the contacts on each side are internally tied together, so there are only two actual signals. The only real thing you need to figure out is which contacts are on which "side" of the switch. Of course, if your goal is an always-closed circuit, connecting all four contacts together will eliminate any doubt.
Nov 2, 2006. 12:35 AMshecktor says:
Very Nice> Will build with kids next year.
Nov 1, 2006. 1:32 PMmever says:
Great take on the laser vortex! Looks awesome and and i love the use of legos for the motor mount.
Nov 1, 2006. 5:15 AMvrogy says:
nice. still, it's technically not a 'cog' on the motor there, it's referred to as a 'pinion'.A cog is a gear that typically meshes between two other, larger gears.A pinion is usually wide to accomodate misalignment, and acts on a single larger gear.
Oct 31, 2006. 10:33 PMDoom_Goat says:
thats awesome, great instructions. video please
Oct 31, 2006. 9:44 PMfungus amungus says:
This made my day. Awesome. The last line is a classic.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:vatosupreme
