3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
JackKnife Style Lockpick
This Instructable is for  responsible viewers who understand the basics of lockpick making but  want to combine their picks into a small portable design. I have found that this design works quite well if you like the look of the Southord Jackknife pick or other similar products on the market but are unwilling to dish out the money for one. I designed mine with only frugality in mind as i did not even go to the hardware store to buy materials. For some of you, this is great news, but for others who want a higher quality pick, you might want to consider investing more time and dishing out some extra money for higher quality materials. Please note that this is not the most well put together design and i will note a few things that you could do to produce better results as all of us weekend builders know: you sometimes never know how to build it right until you've built it wrong. That's why there's Instructables right? Thanks for checking out my first Instructable and feel free to leave a comment. Again, this does not fully show how to make the picks, just how to combine them into a small, pocket sized tool.
NOTE: I MADE THIS BECAUSE AND ONLY BECAUSE I FIND LOCKS AND LOCKPICKING INTERESTING. I AM NOT RESPONSIBLE FOR ANYONE WHO MISSUSES MY IDEAS AND ENDS UP WITH A TRIP TO THE POLICE STATION OR WORSE. PLEASE, DO US ALL A FAVOR AND TRY YOUR HARDEST NOT TO ACT DUMB, EVEN IF YOU WERE JUST BORN THAT WAY. THANKS!
Step 1Materials and Tools
Materials and Tools
Materials :
1. Windshield Wiper Inserts
These are dead useful in the world of lockpicking as they are perfect not only for tension               wrenches but also for smaller picks. You can find them at your local mechanic shop in the trash.
2. Hacksaw Blades
These are hands down the best readily available pick making material out there. Buy them in  Packs of 3 or 5 and get the least expensive ones as which kind you get doesn't matter much.
3. Two Screws and Three Nuts
Find two screws that fit into the holes at either end of the blade when you buy them. Also you
will need three nuts that fit onto your screws.
4. Piece of Rubber Tubing
This is used to hold the tension wrench on the side of the pick's body attached by tape or epoxy
The tools you need are:
1. Screw driver
2. Dremel
3. Bench Grinder (or files if you don't have one)
5. Pliers
6. Drill with Bit that fits into the fore mentioned holes
7. Vice (not neccessary but sometimes helpful)
4 comments
May 20, 2012. 3:40 AMkoenjah says:
Awesome!
Greets from Holland,
http://www.lockpickwinkel.nl
Apr 29, 2011. 6:27 PMmattthomas992003 says:
TRY YOUR HARDEST NOT TO ACT DUMB, EVEN IF YOU WERE JUST BORN THAT WAY, thats the best way putting it
Mar 28, 2011. 7:43 PMdungeon runner says:
I really don't like correcting people, but this always bugs me.
The proper term is torsion or torque wrench. Tension and torsion are two different motions. Tension pulls things apart. Torsion twists or spins them. Therefore, a tool used in the manner of a wrench that is meant to apply turning force is called a torsion wrench, see?
I can see where the confusion stems from - the torsion wrench does seem to "tense" up the lock. But that is a misuse of the word tense, as explained above.
Anyways, great instructable, if I had better tools I would definitely try it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:barricl
