Introduction: Jacket Mod: Stop the Zipper From Catching the Fabric!
You know those little flaps of fabric that cover your jacket's zipper to stop heat loss via the zipper? Don't you hate it when they get caught in the zipper? I fattened those flaps up with thick string so that there'd be no extra fabric to get caught. I could have cut them off but then I'd have a line of cold running up my abdomen and sexy chest. Sad face :(
Step 1: Materials and Tools
String, or similar (thick enough to take up almost all the space inside the flaps, long enough to fill both flaps)
wire (thin enough to be able to pull through the flap while being wound around the string, about 4 inches longer than the flaps)
Pliers
seam ripper
scissors
Pliers
seam ripper
scissors
Step 2: Get Inside Those Flaps
using the seam ripper I opened both ends of each flap, then I bent the end of the wire back on itself to prevent it from snagging when I pushed it through the flap. I then proceeded to push the wire all the way through the flap.
Step 3: Pull That String Through
Once the bent-over end of the wire is out the other side you wind it around the end of the string. Make sure the winding is pretty tight because you don't want it to lose the string halfway through. Also: trim off any excess string otherwise this "knot" wont fit through the flap. Also also: make sure that the cut end of the wire is now facing the other way. I.e: when you pull the wire back through the flap along with the string you don't want it to snag anything. Now you pull the wire through and in so doing pull the string into, and through, the flap.
Step 4: Tie Off the End
once the string comes out the other side of the flap you can cut it off the wire and tie a knot in it to keep it from going back. You could also stitch it to the end of the flap but this worked out easier for me. If you choose my method then pull the knot very tight and trim off any excess string.
Step 5: Tie Off the Other End, Repeat Procedure on Other Side of Zipper
same thing as the previous step with one important difference: You want the string inside the flap to be just the same length as the flap itself. Too long and you'll have little tassles, too short and your zipper will always be bunched up.
What I did to get the length right was this: With the first knot sitting securely in place I pulled and smoothed out the flap (and the string inside), I then cut the untied end of the string roughly 1 inch from it's end of the flap. I then bunched the flap up and pushed it back a bit so that I had about 2 or 3 inches of slack on the string, this makes tying this end's knot easier. I then tied the knot and tried to push it as far to the end as I could. Done, now just smooth out the flap again and you should have one stuffed flap!
Repeat the whole procedure on the other flap.
Step 6: Finito!
Don't think this zipper will get caught again, there's simply no fabric to get in harm's way!
YAY! PARTY HATS AND NURSERY RHYMES!
