Jacks Desk Tidy
Introduction: Jacks Desk Tidy
In order to start your desk tidy you must create a 2D Plane with the dimensions
You must start with dimensions of 80 and 90mm, thick and wide
Extrude it a further 80mm to make the cube shape
Shell it leaving 5mm on each corner piece
Extrude the bottom leaving a buffer on 5mm on the bottom
Extrude 5mm holes on the corner pieces alternating every 30mm
Step 1: Step 2: Transferring Your Design to MakerBot
Make your 3D design file an stl. file then transfer over to make bot
Adjust and scale to sice then lay flat
Step 2: Step 3: 3D Printing
Insert your file on the USB into the 3D printer
Click the designated file on the 3D printer then leave to print
Collect once finished
Step 3: Step 4: Finishing Touches
Start the finishing touches by using sanding paper to get rid of all the excess loose plastic
Remove the base from the bottom of the piece so the cube is stand alone
Cut the polypropolene to the shape of the the interior of the box
Step 4: Step 5 Placing in the Polypropelene
Drill 5mm holes into the plastic material
Place rivets into the plastic through the box
Make sure they are tight in place
Enjoy your desk tidy!!!
Step 5:
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
