Introduction: Jagged Alliance Themed Digital Picture Frame
Picture of Jagged Alliance Themed Digital Picture Frame
Several weeks ago I came across some videos of a technique of spray painting camo pattern with leaves and branches and I wanted to try that out. I took the last Ikea frame I had lying around and just started spraying. After that, I did not know exactly what to display in that frame and so it just collected dust since then. A few days ago I remembered that I bought an old, really, really cheap digital picture frame on ebay.
Every now and then I play some Jagged Alliance and then the idea of displaying some characters in the frame came to my mind.
This is the short 'ible of how I put this together...
Videolink
Things I used for this project:
  • Ikea picture frame
  • Spray paint - I used brown, grey and black
  • Strip of wood
  • Digital picture frame
  • Regular household tools
  • and a printer
Step 1: Spraying the Frame
Picture of Spraying the Frame
As mentioned above this was the first try of spray painting something with holding leaves between the object and the spay can. I think with different branches the result would be better, but for the first try and the purpose I am using it, the color palette and combination worked out fine.
Step 2: Inserting the Monitor
Picture of Inserting the Monitor
To get the monitor inside the frame I had to remove its' casing by simply unscrewing every screw I could find. That left me with the monitor and the pcb. These together were flat enough to fit in the frame.
I sawed two strips of wood which fit inside the spacer and glued the monitor to the sticks and the sticks to the spacer.
Step 3: Printing the Passepartout and Assembly
Picture of Printing the Passepartout and Assembly
Since the opening in the original passepartout was too big for the screen I took a sheet of thin cardboard and cut a new one. But just the white paper around the monitor looked boring, so I printed out a part of the map of Metavira and with some spray adhesive I glued it to the cardboard.
Before the final assembly, I took some screenshots of the characters of the game and cropped them to size, saved these to the sd-card and everything was ready for putting together.
If you power the frame up, every 10 seconds a random face appears in the middle of the map.
Thank you for taking the time reading this short story of a project you can do without fancy tools or skills.
spiderobert (author)2016-05-11
this is very cool. I think I'm going to try to do this with some other game themes.
ChristophF1 (author)spiderobert2016-05-11
Thank you very much! Would be happy to see the idea adapted. Please keep me posted!
About This Instructable
2,225views
12favorites
License:
More by ChristophF1:Animated Doom Picture FrameConcrete Lamp - This Was a FailureJagged Alliance themed digital picture frame
Add instructable to:
