Introduction: Bluetooth Backpack Speaker
This speaker is easy to make and for me was free (I had spare parts lying around)
For this project all you need is basic soldering skills!
Thats it! Time for step 1!
Step 1: Watch the Video
This video will pretty much summarize the project details. While your at it, subscribe vote and comment for more projects like this. Once your done, Lets head on over to step 2!
Step 2: Supplies
All you need for this project is
- A Cheap Backpack
- Speaker
- Bluetooth headset (any Bluetooth earpiece)
- Hot glue Gun
- Knife
- Soldering gun w/ solder
Thats about it! Thats how simple it is to make! For me I had all of these lying around so it was free to make. The bluetooth headset was a half working and was donated to me by a friend. For this project however, I provided a link to a cheaper more affordable unit.
Step 3: Pop of Case to Headset
Begin by popping of case to Headset. Start with the battery and work your way to the earbuds.
- You'll notice that only one is wired to the bluetooth component, the other is wired to the first earbud. Remove the earbud without the Bluetooth, most likely this will the one without "buttons" or controls on it.
Picture one Is the removed earbud
Picture three is the earbud to keep
Next Step!
Step 4: Break Off Earbud
Break off the earbuds speaker, we will rewire this later. The part to remove is the silver part. If you still cant tell, watch the video thats in the intro of this instructable. It walks through the steps of building this project
After you remove the tiny speaker, you will notice there is two TINY wires sticking out from the earbud (sorry hard to photograph). We will use this later
Next Step!
Step 5: Connect Speaker to Earbud
Connect the + to + on the speaker and - to -
If there is no indicators, you may need to test the wires by simply pressing them together. Mine however had little indicators indicating positive or negative
Next Step!
Step 6: Test If Bluetooth Works
Connect the Bluetooth to your phone and play any sound to see if it works.
If no sound is coming out, you may need to repeat the previous steps until it works. Most likely your polarity is switched on your speaker
If it works, AWESOME! now we just need to put it in the backpack!
Next Step!
Step 7: Insert Speaker
Trace the bottom part of your speaker driver onto the middle of your backpack and cut it out using your knife. All I did was cut out a big plus sign and jammed the speaker into place. Thats Pretty much all you need to do!
After sealing the speaker with hot glue, It started to look very nice. I cut another line to the right of the speaker in order to fit the control unit through. Your headset however might not have this.
Ne
Step 8: Jam to Your Music
Show your Jampack to the world. Blast your music anywhere your Jampack takes you. Most likely you will be the personal DJ for your group of friends who you show this to. Most people will be amazed that you made this and will try to play their music over your Jampack.
Future Plans!
To add in a Op Amp Circuit!
Please Vote for this instructable in the contests! Thank You!
