Japanese / Oriental / Asian Inspired Candle Holder
2,493
32
9
Posted in WorkshopWoodworking
Introduction: Japanese / Oriental / Asian Inspired Candle Holder
About: I hope i can show you that you really dont need to be a master craftsman to create and build great projects, and hopefully inspire you to start making yourself. I will try upload a video every Monday but du...
I wanted to make something special for my mum's birthday present, and after searching for a unique candle holder i realized there wasn't a Japanese / oriental style one.
So i came up with this, a Japanese / Asian / Oriental inspired tea light and incense candle display.
Hope you like it !
Follow my work on Instagram - https://www.instagram.com/ggwoodproje...
Help me make more projects- https://www.patreon.com/GGWoodwork
OR
One time tip - https://www.paypal.me/GGwoodwork
Thanks
GG
Step 1: Cut Legs
I started by cutting the legs out, after i had the rough cut outs i thought it needed something else, so i tapered the bottom of the legs .
Step 2: Cut Braces
For a contrast in color i cut out stretchers / braces from meranti.
Step 3: Plane
I didn't want to do much sanding so i set my plane up to smooth out the surfaces. I taped the brace / stretcher pieces together do they would be exactly the same size.
Step 4: Wood Burn & Glue Up
For an extra touch i added the Japanese symbol for light on the front stretcher , this was wood burned in.
Next i started gluing up the base, i chose to do this in stages as it was much easier to clamp in parts and the glue everything up.
Step 5: Rip & Cut Body
Now that the base was done, i moved onto the body of the piece, i started by ripping a 2x4 and some more meranti into strips.
Step 6: Glue Up & Shape
Once the strips where planed flat i glued them together to make a tray essentially, once the glue was dried i made a lot of relief cuts and chiseled out some of the body, this gave it a arc shape making it much more interesting than a straight piece of wood.
Step 7: Sand
I then sanded everything at 320 & 500 grit to get a nice glass like feel.
Step 8: Final Glue Up
next i glued the already complete base onto the tray and added some weight while it dried.
Step 9: Finish
As always last the last step is the finish, i used some clear gloss finish, brushing on 5 coats and sanding at 500 grit between coats
Step 10: Add Candles & Insense - Job Done
Thats it - job done.
All i did to finish it off was add the candles and a Buddha ornament that i drilled a hole in to hold incense.
I love how its turned out , and so did my mum so is a win win.
I hope you liked it as well, hopefully its nothing you've seen before.
Help me make more projects - https://www.patreon.com/GGWoodwork
OR
Thanks
GG
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    9 Comments
    you definitely can't just call vaguely asian designs "oriental." it's offensive and ignorant.
    im sorry you feel offended by my wooden candle holders. You'll find i never called it oriental i said it was inspired by, i am not ignorant i was simply stating where the design inspiration came from.
    Yes, and it's not like you're ignoring what people had said, as you stated in one of the comments above, you have taken on board what people have said have done nothing wrong; a great instructable.
    Very nice! Great idea!
    I love your "inspired" candle holder! Nice work.
    Oops. I think you ment to say, Asian, not Oriental. The Orient is the area we know today as the Middle East.
    Thank you for pointing it out , it has been added to the title , hopefully this better explains where my idea's came from
    I should have listed asian but it was a mixture of Asian, Japanese & Oriental that ispired the design.
