Step 3Rout Base for Cable
1. If you have a Dremel (as I do) carve out the channel using your favorite method. I used the straight edge attachment and the multipurpose cutting bit. I started with the tool in the middle and cut a straight line to to edge. Be sure to clamp the base down when you are working on it. Other options include cutting the slot freehand with a high speed cutter or using the plunge router attachment. Maybe even using a chisel if you want to go old school.
Add Comment
