(note: the firefly behavior in this video has been greatly sped up in order to be easier to represent in a short film. The default behavior has significantly more variance in its brightness and delay between plays.)
Remove these ads by
Signing UpStep 1About this Project
The flash patterns have been digitized from firefly behavioral research data found online and were modeled in Mathematica so that variations of speed and intensity could be generated. The final output was transformed by a lightness function and written into header files as 8-bit PWM data.
The software is written in avr-gcc C and source code is provided along with a pre-compiled .hex for convenience. The code has been significantly optimized for efficiency and to minimize power consumption. Crude runtime estimates predict a 600mAh 3V CR2450 battery should last between 4 to 10 months, depending on the song pattern used. RIght now the source comes with two patterns, song1 and song2, with song2 as default. Song2's estimated runtime is 2 months, song1's is 5 months.
This project involves a fair amount of surface-mount level soldering. However the circuit design is trivial and the fact that we're able to use an off-the-shelf SMD prototyping board rather than having a custom PCB made greatly saves on cost. It would be very simple to create a non-surface mount version using the PDIP version of the ATTiny45 and through-hole LED's.
The cost of the electronic components comes in at around $10-$15 (after shipping) or so and assembly time is on the order of 2 hours.
i'm doing a couple of jars for my balcony, i bought enough components for 10, so I did a trial run, and soldered everything on, programmed the attiny and just going to test it with one led, so i attached the batterypack and the led is lighting up, but its just on and off, no fading at all.
What could be the problem?
The Polou boost circuit is a great suggestion. It is small, very efficient, and low cost.
An alternative (lower cost) idea is to use a MAX756. Should be noted though, in QTY 1 a max756 is almost $5, but Maxim is very liberal with free samples (I even put "Hobbyist" in as my company name, though I did use a business email address). An advantage is the 756 can be configured for 3V so you can use smaller resistors and power lasts longer.
But it may be easier to get the solar charger to charge 2 batteries...
http://www.instructables.com/id/Wedding-Firefly-Fishing-Floats/
Thanks Keso!
-Nick
Don't want to sound desperate but I am. I relly love her and would like to give her a jar of sand from the edge of the ocean and a jar of firelies : )
I'll pay any fair price if someone has one made or would be willing to make.
Thanks in advance to all
Mike ueiservice@yahoo.com
Thanks so much for this instructable. It was a lot of fun to build and very rewarding once I got it to work.
If anyone needs help with the programming feel free to contact me
http://www.instructables.com/id/Help%3a-An-Absolute-Beginner-s-Guide-to-8-Bit-AVR-Pr/
First, digikey does not have any tiny45s in a 9081 footprint, are there other similar chips I can use (I know I'd have to modify the code slightly). A second option that I'm seriously considering is to use expressPCB and make a custom board.
Second, I only have a 1" hole to insert my firefly leads through. I need to find a way to distribute them throughout the sphere. Anyone have any ideas besides using double sided tape?
Thanks!
Nick
