Jar of Flashing Lights
 by botronics
A simple oscillator using a 74HC14 CMOS inverter makes a excellent driver to flash leds. Put them in a jar and place it in your window for a showy display.
Step 1: Make the circuit
Run four vertical bus wires of bare #18 wire between the top lid and bottom disc in the jar. I used a thin phenolic material to support the bus wires. One disc to replace the top lid of a Ball canning jar and one on the bottom for support. You could use perf board material that has copper pads.
One of the wires is used for the positive bus and the other three are negative. I start by spreading out the positive (pin14) and negative (pin7) of the ICs. Solder and support the ICs to the bus wires.
thatoneguydavid says: Dec 4, 2009. 11:41 PM
this looks really cool, but if you added current limiting resistors in series with your LEDs you could normalized the light output so all of the LEDs would have the same brightness.
botronics (author) in reply to thatoneguydavidAug 21, 2012. 6:15 PM
Thats too much trouble.
botronics (author) says: Aug 21, 2012. 6:13 PM
I also have a video of the project at my Youtube Channel.
http://youtu.be/5jz2CKoj_V8
tvholliday says: Aug 21, 2012. 1:44 PM
Great project... can you tell me more about how it is powered... since it is in a jar, did you use batteries (what total voltage) or ac?
botronics (author) in reply to tvhollidayAug 21, 2012. 6:09 PM
I used a 5 volt wal-wart power supply. Such as ones used to charge your cell phone. On the top of the jar I placed a connector for the power supply. You can get the power supplies at a thrift store ($1.50) or a electronics surplus dealer such as Electronic Goldmine for 5 bucks. Sorry I forgot to mention that in the instrucable.
botronics (author) says: Aug 21, 2012. 6:03 PM
By the way, the circuit is powered by a 5 volt wall-wort.
ramekbass says: Jul 15, 2009. 2:28 AM
nice project man.keep it up bro.
electfire says: Jan 31, 2009. 5:42 PM
That is frigging awsome !
roboman01 says: Dec 30, 2008. 1:47 PM
You could also make it into a BEAM pummer. It would probably be cheaper than the garden light.
sr1sws says: Dec 27, 2008. 6:01 AM
Cool. Now you just need to provide power to it via inductive coupling... sit it on it's base to power up... like a rechargeable toothbrush.
botronics (author) in reply to sr1swsDec 27, 2008. 9:54 AM
You could supply power from a solar garden light. The solar unit is about the same size as the jar top. I took one apart and wrote about it here.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
