Java Basics
393
20
Posted in TechnologySoftware
Introduction: Java Basics
Learn to Use Java
Step 1: Open Notepad
Step 2: Enter the Code
In writing a java program, it always begin with public class _________(Enter the name of your Program)
Then Write the code provided
public class Sample
{ public static void main(String args[])
System.out.println("Hi...This is my First Java Program");
It is necessary that you should all the things given above or simply copy them
Step 3: Saving It
When you are going to save a java program, it is necessary to write the same name which you have written in the class name with a '.java' extension
Step 4: Running a Program
Then you have to open cmd
For opening cmd just type it in the search box and do the following steps
  1. Navigate to the place where you saved your program in cmd
  2. Then type 'set path=C:\Program Files\Java\jdk1.8.0_101\bin' but change the version according to your jdk.
  3. Press Enter
  4. Then type 'javac'
  5. Then type 'javac Sample.java' Where I have type Sample.java you have to replace it with your file name
  6. If any errors were there then it would be shown on the screen.
  7. After correcting those errors do the 5th step again.
  8. Type 'java Sample' Where I have type Sample you have to replace it with your file name.
  9. Your program is ready
Step 5: Important Points
  1. Your class name should start with a capital letter
  2. While typing your message, you should add inverted commas or it will show errors
  3. After typing your message, add a colon (;).
I hope you like this ...
Thanks
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    3 Comments
