Java Program - Compounding Interest
3,026
Posted in TechnologySoftware
Introduction: Java Program - Compounding Interest
About: Occupation: Tech Support
// This program determines the amount of money that is compounded at 8%
// over time (subtracting 30% per month for taxes.
// Run this program from the command line.
// User is prompted to enter the number of years that they want to invest,
// amount that they want to deposit each month and the initial amount.
// Results sent to screen and text file.
// Distributed under the GNU GPL: www.gnu.org
import javax.swing.JOptionPane;
import java.io.*;
import java.text.DecimalFormat;
class Compound9
{ // Start class Compound9
// Declare variables
float mike, mike2, mike3, mike4;
float interest; // Interest amount
float amount, amount2; // Initial amount invested
double i=1;
float months, months2; // Number of months money is going to be
// deposited/invested; calculated from years
float MonthlyAmount; // Amount deposited each month
float initial, initial2; // Initial deposit
float years, hotel2, hotel3;
int n;
String line;
String bravo;
String charlie;
int delta, redhat;
int echo;
int foxtrot;
// Method to ask user to enter in number of years
// Method returns float
float NumberYears() throws java.io.IOException
{ // Start NumberYears method
int delta = 0;
float hotel; // Number of years money is going to be deposited/invested
hotel = 0;
String alpha;
do {
try {
// Print input question to screen
System.out.println("\nHow many years do you want to invest?");
// Use the standard input stream in the System class, feed keyboard input
// into variable "isr" of InputStreamReader class
InputStreamReader isr = new InputStreamReader(System.in);
// Feed information from variable "isr" into variable "br" of BufferedReader class
BufferedReader br = new BufferedReader(isr);
// Reading the Buffered Reader "br" into the String variable "alpha"
alpha = br.readLine();
// Cast String "alpha" into an float and return result
// to main part of program
hotel = (Float.parseFloat(alpha));
delta++; // Increment do-while flag variable if a number is entered
} // end try loop
catch (IOException golf) { // Start catch for IOException
System.out.println("IO Error - error caught: " + golf.getMessage());
golf.printStackTrace();
} // End catch IO Exception
// Catch exception if letter is entered
catch (NumberFormatException echo) {
System.out.println("You did not enter a number.");
System.out.println("Error caught; you entered: " + echo.getMessage());
echo.printStackTrace();
// When program reaches this point, delta is still 0
// therefore it will do the loop again
} // End catch
} // End do
while (delta == 0);
// returns value in hotel to main program
return hotel;
} // End NumberYears method
// Method to get amount deposited each month from user
float MonthlyDeposit() throws java.io.IOException
{ // Start MonthlyDeposit method
do
{ // Start do loop
try
{ // Start try section
System.out.println("\nHow much do you want to deposit each month?");
// Reading the Buffered Reader "br" into the String variable "bravo"
bravo = br.readLine();
// Cast String "bravo" into an float
hotel2 = Float.parseFloat(bravo);
// If exception is thrown on the line before, foxtrot++ is skipped
foxtrot++;
} // End try section
catch (IOException xray) {
System.out.println("IO Error - error caught: " + xray.getMessage());
xray.printStackTrace();
} // End IOException
catch (NumberFormatException hp) {
System.out.println("Error caught; you entered: " + hp.getMessage());
hp.printStackTrace();
// Foxtrot is still zero at this point
} // End catch for NumberFormatException
} // End do loop
// Flag that determines when do-while loop ends
while (foxtrot == 0);
return hotel2;
} // End MonthlyDeposit method
// InitialAmount method gets the initial amount invested
float InitialAmount() throws java.io.IOException {
do { // Start do loop
try {
System.out.println("\nHow much is the initial investment?");
// Feed keyboard input into InputStreamReader "isr"
// Feed InputStreamReader into BufferedReader
// Read the BufferedReader into variable "charlie"
charlie = br.readLine();
// Cast String "charlie" into float and put into variable "hotel3"
hotel3 = (Float.parseFloat(charlie));
redhat++;
catch (IOException redhat2) {
System.out.println("IOError - error caught: " + redhat2.getMessage());
redhat2.printStackTrace();
} // End IO catch statement
catch (NumberFormatException suse) {
System.out.println("You did not enter a number");
suse.getMessage();
suse.printStackTrace();
} // End of NumberFormat catch
} // End do loop
while (redhat == 0);
return hotel3;
} // End InitialAmount method
// NegativeCheck method checks for a negative number
float NegativeCheck(float kilo) {
if (kilo < 0) {
System.out.println("Please enter a positive number.");
mike = 0;
} // End if statement
else {
mike = 1;
return mike;
} // End NegativeCheck
float months() // Method to calculate number of months
months = years * 12;
System.out.println("The number of months is: " + months);
return months;
// Method to calculate interest, print it out to the
// the screen and write it to a file
float calculate(float months3, float initial2)
try // Loop to try to write to a file
File temp = new File("Compound9.txt"); // Create new file
FileWriter fw = new FileWriter(temp); // Create new FileWriter
BufferedWriter out = new BufferedWriter(fw);// Create new BufferedWriter
// Pass initial2 into variable "amount"
amount = initial2;
// Calculate interest for the first month
// Calculate monthly interest (.08/12)
// 8% annual growth (historical avg for stocks)
interest = (float)(amount * .00667);
// 20% taxes taken out
interest = (float)(interest * .8);
// Interest added to running total
amount = (amount + interest);
// Format the output to 2 decimal places and put a comma in (US style)
DecimalFormat roundTwo = new DecimalFormat("###,###,###,###.##");
// Information placed in the String object "line" to be sent to file
line = ("The amount after " + i + " months is $ " + roundTwo.format(amount) + "\n");
// Information sent to screen
System.out.println("The amount after " + i + " months is $ " + roundTwo.format(amount));
// Write String "line" to file
out.write(line);
// NOTE: The reason that the first month interest is separate from the main loop is
// because I wanted to make sure that the first month's interest was only calculated
// for the initial deposit, not the initial deposit plus the first month's deposit.
// Loop calculates from month 2 onward
// Start for loop to determine compounding interest; limited by the number of months
for (i = 2; i <=months3; i++)
// Add monthly deposit to total amount
amount = (amount + MonthlyAmount);
// DecimalFormat roundTwo = new DecimalFormat("###,###,###,###.##");
out.write(line);
} // End for loop
out.close(); // Close text file
} // End try loop
catch (Exception e) { // Catch exception if fail to write file
S
    • Space Challenge
      Space Challenge
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
