3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Je suis un espion: Key mold
Be a super secret, covert spy with simple homemade tools such as this Key Mold. This is a tool for making molds of people's keys while they are still on the ring. "Why would I want a mold of a person's keys?" you’re asking yourself. Well with a mold of a key a copy could be made to allow you to access all sorts of locked... well, locks.
As with all potential unlawful behavior associated with the use of these tools I accept no legal responsibility for your actions or the digestion or use of this information.
This is my first Instructable PLEASE COMMENT and tell me what you think.
Step 1Gather Your Supplies...
  • C:\Documents and Settings\Samuel Vsetula\My Documents\My Pictures\projects\DSC04554.JPG
  • C:\Documents and Settings\Samuel Vsetula\My Documents\My Pictures\projects\DSC04559.JPG
  • C:\Documents and Settings\Samuel Vsetula\My Documents\My Pictures\projects\DSC04557.JPG
  • C:\Documents and Settings\Samuel Vsetula\My Documents\My Pictures\projects\DSC04556.JPG
  • C:\Documents and Settings\Samuel Vsetula\My Documents\My Pictures\projects\DSC04558.JPG
  • C:\Documents and Settings\Samuel Vsetula\My Documents\My Pictures\projects\DSC04555.JPG
For this project you will need the following:
1. Small hinged tin (Altoids work well)
2. Tin snips (Scissors may work)
3. Clay
4. File (Optional)
5. Keys (from unsuspecting mark)
95 comments
1-40 of 95next »
Apr 12, 2012. 7:13 AMspringheeledjack says:
just fill with wax, let harden, place resulting wax key gently into plaster, after plaster sets heat and pour our wax, fill plaster mold with molten metal, high strength epoxy etc, gently break away plaster
you now have a key
Oct 17, 2011. 1:31 PMcabello says:
After this, how do you make another copy of the key ? Do you go to a store or can you do it yourself ?
Sep 24, 2011. 2:27 PMmooner77 says:
if u melt down metal use bismuth low melting point can be melted on stove.
Nov 26, 2010. 5:45 PMMerteuil says:
Hey SWV, I like your instructable, but think it could be improved upon by moving the notch to the side a bit more, then making another notch on the other side of the tin diagonal to the first notch. Then both sides of the key could be duplicated, and lined up for filling. It could be possible to have both parts line up well enough that they could be pressed lightly together to ease the filling/cooling process for the duplicate with some thinking.
Then again, one could just fill the impression with whatever metal they've got around, then remember the style/shape of the key they're copying and request their semi-key to be cut using a store's proper blank.
Nice one!
Oct 26, 2010. 4:28 PMjuzzy123 says:
melt metal and pour it in and you can copy your own key
Feb 14, 2010. 5:23 AMairicknuin says:
 any comments on ABS plastic?
Nov 14, 2009. 5:44 PMjunits15 says:
Je n'suis pas un espion. I dont know much french :)
Jul 22, 2009. 5:36 PMnobelium106 says:
to make the key, somebody could pack the mold with baking soda, the put some superglue on it. It quickly hardens to a stone-like material.
Oct 17, 2009. 1:23 PMmr j124 says:
have you done this before
Oct 18, 2009. 3:15 PMnobelium106 says:
Not to make a key, but for anything else that needs a strong filler, it works great
Oct 19, 2009. 5:48 PMmr j124 says:
ok ty for info
Jun 19, 2008. 7:15 AMnerd12 says:
you can put wax or clay in the clay to make it a key
Nov 27, 2008. 10:40 AMEvil Bike says:
that won't work to open the lock, wax breaks, clay disfigures
Jul 11, 2009. 10:35 PMnerd12 says:
or you could use the lost wax method. it was used by Indians in the indus valley. they would make a wax model of the desired shape (like a statue) then cover it with earthen clay. when the clay dried and set they would melt the wax and pour it out. then they had a perfect mould. they would then pour molten metal into the mould and leave it to harden. after hardening break the clay mould and you have a statue left.
Jul 11, 2009. 10:28 PMnerd12 says:
not plasticine potters clay or m-seal
Aug 13, 2009. 8:06 AMstevie1 says:
or jb weld?
Mar 18, 2010. 12:11 AMnerd12 says:
if it stays hard and does not break then ok.
it should also be heat ristance
Jul 7, 2009. 5:07 PMReCreate says:
Perhaps solder?
Jul 8, 2009. 12:22 PMEvil Bike says:
solder wont be able to mole perfectly to it it beads, not sets
Jul 8, 2009. 1:53 PMReCreate says:
what?
Nov 12, 2008. 12:36 PMplowboy07 says:
what would you use to make the copy to be used
Jul 10, 2009. 11:35 PMScythe1157 says:
You could buy or obtain a blank key close to the molded one and carve out the teeth yourself.
Dec 9, 2008. 3:25 PMking of shaws says:
Try using solder!
Jun 25, 2009. 2:00 AM11richie21 says:
solder will just stick to the gun
Nov 27, 2008. 10:39 AMEvil Bike says:
you could use a putty, or something different from the clay
Jun 25, 2009. 2:04 AM11richie21 says:
i used cheese once in Vietnam they fed me milk that was unprocessed and stale bread! they locked me up so i had the milk sit there and i stired it with my finger until it turned in cheese. then i made a mold out of the clay under the dirt floor. I just had to keep digging
May 21, 2009. 3:40 AMzac_sraw says:
what about filling it iwth fimo, taking the mould baking it put more fimo in imprint take it out then bake that?
May 12, 2009. 5:33 PMfire_drakon117 says:
if you want to add a bit of realism add cardboard and put small washers over it so that when its rattled it sounds like there are mints
May 6, 2009. 1:43 PMshadysideguy says:
ya
Oct 2, 2008. 9:33 PMninelivecat says:
If you make the mould as in above you could make a copy by melting some lead to get the keyshape but the lead copy would be too soft to be functional unless you could spray something like super glue onto it I was thinking epoxy resin or milliput might wotk too you could make the key out of plastic or fibreglass possibly
Oct 19, 2008. 10:10 PMThe Expert Noob says:
you might could electroplate something onto the lead to make it stronger?
Apr 25, 2009. 9:44 PMthe_mad_man says:
electroplating only leaves a layer a couple of microns (100th of a mm) thick, so I don't think plating world make it any stronger
Sep 10, 2008. 8:38 PMlobo_pal says:
Why not use homemade salt dough, then you can harden it yourself at home?
Apr 13, 2009. 4:19 PMzvillesurfer says:
no salt dough crumbles. i've made it before for school, and if you tried to put pressure or anything on it it would probly just snap. if you ask me, i would melt some colored wax into the mold, then take a high resolution picture of it, print it out, and try to carve that out of something like a soda can.
Apr 14, 2009. 5:47 AMlobo_pal says:
There are many types. I've used some that are pretty strong.
Sep 20, 2008. 5:42 AMMasteroffencing says:
isnt salt dough just homemade playdough
Sep 20, 2008. 4:46 PMlobo_pal says:
Yeah, except for the different qualities they have. I know how to make 5 types, but there could be more.
Sep 12, 2008. 7:44 PMDIY Dave says:
how do you make salt dough?
Sep 12, 2008. 9:24 PMlobo_pal says:
There's several ways to make it, it depends on what qualities you want. Some dry in air, some have to be baked, some have a few ingredients, some have more. What is it that your looking for?
Sep 20, 2008. 2:40 PMDIY Dave says:
what do you mean by what qualities?
1-40 of 95next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:SWV1787
