Step 4Personalize your Apron
(You will see that I have already done step 6 before this one. I suggest doing this first.)
Cut a pumpkin shape out of the tag. Sew around it onto one of the pockets.
Using the zipper pull as a stem, hand sew it onto the pumpkin. You will notice there are no staright holes on both sides of the zipper pull to run your needle & thread through. Run your needle through the pocket, next to the zipper pull. Loop the thread between the grooves of the zipper pull several times, then run it through the other side through the pocket and tie it off. This will secure it to the pocket.
Cut your zipper pieces very close to the metal slats. Sew it to the bottom/middle of the pumpkin by looping the thread though the slats, and back through the pocket.
Wind the zipper into a small loop, and secure it using the same method above.
Do the same to the other side.
Your zipper has made some vines for your pumpkin.
Add Comment
