Jeans Cuff Wallet
Step 4Cut the Wallet Pieces
You need:
One piece for the outside of the wallet. This one is approximately 8 3/4 inches wide by 3 1/4 inches high.
One piece for the inside of the billfold. It needs to be shorter (less wide) than the outside piece. How much shorter will determine how much you can stuff in the wallet and still get it to close. This one is 1/2 inch less than the outside piece (or 8 1/4 inches). Keep in mind that the denim will likely stretch over time.
Depending on the overall length of the cuffs after being cut open, you will likely get the inside piece from one cuff and the outside piece from the other cuff. I recommend not centering either piece over lapped seam. It makes the wallet less able to fold flat.
The pieces remaining after cutting the inside and outside pieces will be used for pockets.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:littleberry
I make pretty pictures. I make sites for the web and things that are interactive and sometimes I make interactive things that also move. I make things to wear. I make things to play with. Sometimes I ...
more »
