Jelly Doughnut Recipe
 by randofo
Featured
After making apple cider donuts, I was left to wonder exactly how jelly doughnuts were made. This problem started to eat away at me, leaving me with a large empty feeling inside. I needed to figure this out and be whole again. So, I set out to fill my spiritual cavity with the sweet gelatinous knowledge of jelly doughnut making. In the process, I learned a thing or two about the process. For one, jelly doughnuts are a total mess to make and secondly, jelly donuts are even more delicious when you make them yourself. I would even hypothesize that an individual hasn't fully lived until they have fully made jelly donuts.
Step 1: Ingredients
You will need:
4 1/2 cups of bread flour
1 tsp salt
1 envelope dry active yeast
1 cup milk (plus some for later)
2 tbsp sugar
2 eggs
2 tbsp unsalted butter
A jar of raspberry and/or strawberry jelly
Powdered sugar for coating
Enough vegetable oil to fill your container to a depth of at least 2"
Step 2: Prep work
Let a cup of milk cool to room temperature.
Melt 2 tablespoons of unsalted butter and let it cool.
Step 3: Mix the dry
Combine 4 cups of flour and 1 teaspoon of salt until good and mixed.
Step 4: Activate your yeast
Stir together 2 tablespoons of your lukewarm milk and 2 tablespoons of sugar.
Pour in your dry active yeast and let sit for approximately 10 minute until it starts to bubble and foam.
Step 5: Mix in the wet
Mix in your activated yeast, followed by the remainder of the milk, followed by two well-beaten eggs and finally the melted butter.
If using a standing mixer, replace the mixer attachment with the dough hook.
Step 6: Knead the dough
If you have a standing mixer this is really easy.
First make sure you have the dough hook attached and then turn the mixer on to low.
Simply add the remaining half cup of flour by small additions, while alternating with small additions of milk until the dough is smooth and pliable.
If you are not using a standing mixer, you will have to knead it by hand. Repeat the same process with the flour and the milk until the dough is smooth and pliable.
Step 7: Let rise
Place the dough in a lightly oiled pan and let is site for around two hours until the dough has doubled in size.
Step 8: Wait
Here is your opportunity to wash the dishes you have used thus far, clean the counter and prep for the remainder of the process. None of this should take two hours.
Use the remainder of the time to play Metroid. Assuming that you are out of practice at Metroid, I have included a cheat code below to help you along.
Step 9: Roll out the dough
Once the dough has risen, lightly flour a clean work surface and your rolling pin.
Flatten the dough in the bowl and then roll it onto the floured surface.
Using your rolling pin, spread the dough out until it is around a 1/2" thick.
Step 10: Cut out donuts
With a cookie cutter, cut out 3" rounds from the flattened dough and place them onto a lightly floured cookie sheet.
Keep re-balling and rolling out the dough until you can't cut out any more doughnuts.
When you are done, place them somewhere warm for roughly 20 minutes and allow them to double in size.
Step 11: Prepare to fry
While you are waiting for the doughnuts to rise, now is a good time to do some prep work since the next few steps all happen very quickly and in some cases simultaneously. It is important to make all of the following preparations first. I turned the kitchen into a disaster zone trying to do all of this at once, but I imagine it will be slightly easier if you also aren't trying to take pictures at the same time.
First things first, fill a large and tall pot with 2" - 3" of oil. Attach a candy thermometer to the pot and put it on a medium flame so that it can slowly start building up to 350 degrees. The goal is to keep the oil at 350 degrees. That is 350 degrees Fahrenheit. Keep the oil at 350 degrees.
Next, you are going to want to spoon your jelly into a pastry bag with a 1/2' metal tip. The metal tip is important for effectively stabbing into the cooked doughnut.
Lastly, fill a bowl with a generous amount of powdered sugar. This will be used to coat the scorching hot newly fried doughnuts.
Step 12: Fry!
Once the oil hits 350 degrees, carefully use your spoon to place them into the oil. Flip them often. Continue cooking until the look golden, doughnut-like and delicious.
Carefully remove them from the oil using metal tongues. Being careful not to touch them (heated oil is hot), use a metal spoon to roll them around and coat them in powdered sugar (don't do as I did in the pictures. I got some nasty burns).
Transfer the coated doughnuts to a plate, but whatever you do, don't let them cool too long before adding the filling! (see next step)
Step 13: Add filling
Stab the side of a doughnut with your pastry bag and squeeze in jelly until you start to feel resistance as though the pastry bag is being pushed back out of the doughnut. This is indication that your doughnut is ready to eat.
Repeat until all the doughnuts are ready to eat.
radman5 says: May 12, 2013. 4:06 PM
These look amazeballz! I will attempt these on Wednesday (my day off) and am very very excited. I want to create these on a regular basis and give/sell(depending on how good they turn out) to the other students in my neighbourhood till I am legend and then I will be known as the Doughnut Dealer. 8)
scoochmaroo says: Jan 12, 2010. 2:57 PM
These look yummy. And I don't even like jelly doughnuts!
arjannugteren in reply to scoochmarooFeb 11, 2010. 8:17 AM
HERESY!
get the inquisitors!
bajablue in reply to arjannugterenAug 27, 2012. 4:43 PM
;-D
tristan993 in reply to scoochmarooJan 14, 2010. 4:35 PM
yeah thats the craziest thing ive ever heard
korgoth25 in reply to scoochmarooJan 13, 2010. 1:28 PM
WHAT!!!! How can you not like jelly doghnuts?!?!
bajablue says: Aug 27, 2012. 4:41 PM
OMG these look delicious!!! ;-P~
susanchen2011 says: Jul 25, 2012. 12:45 AM
It makes me drool.
spark master says: Jun 24, 2011. 6:34 AM
Did you mean let milk warm to room temp or did you heat it then let it cool. Scalding does make a difference, (could make them better, dunno)
spark master says: Jun 24, 2011. 6:31 AM
thanks, I do fried dough enough during th eyear , but never tried to fill them, but mine are never made this puffy. I am using plain old pizza dough. I will give these a whirl in the fall, when times are cooler.
thanks
sparkie
spark master says: Jun 23, 2011. 7:13 AM
about how long does it take to deep fry the donuts so we know when to think they are done? Of course keep oil at the proscrined 350 degrees is helpful! nice instructable
randofo (author) in reply to spark masterJun 23, 2011. 8:18 PM
I am not really sure. Once they started to golden I took them out. Perhaps they were in for a minute or two.
SageMinto says: Feb 22, 2011. 12:07 AM
Mmmm I love jelly doughnuts! :D
This looks like a keeper.
korgoth25 says: Feb 14, 2010. 5:42 AM
ON step 7 you might want to specify each side should be lightly oiled or have a cloth put over it so it doesn't dry out. other wise i just made these and they were great!
gummypaul says: Feb 14, 2010. 4:14 AM
I've wanted to try to make donuts for awhile now. Instead of filling with jelly I guess a person could cut out the rounds and use a pill bottle to cut out the holes. Have you ever tried that? Except for the eggs, this recipe looks like my bread recipe.
zascecs says: Feb 13, 2010. 9:32 AM
Those doughnuts are looking good! Gotta try making them soon!
Meggz says: Jan 31, 2010. 11:25 PM
My husband & I are making these for VALENTINE'S DAY to eat together!!!  He is a Chef, and I am real good at eating so sounds fair enough to me hahaha!
Thanks Randofo, Happy V Day.....
Zem says: Jan 25, 2010. 3:58 PM
 OH. MY. GOSH! I love you Randofo! I will have to make these soon.
Jawa888 says: Jan 15, 2010. 12:06 PM
 MMMMMMMMMMMMMMMM Doughnuts
Doctor What says: Jan 12, 2010. 8:28 PM
 I like it when you mess around with donuts (especially when they are minty and chocolatey).
MOAR!
Kryptonite says: Jan 12, 2010. 2:48 PM
Mmmmmmmmmm looks delicious! Your cooking abilities are amazing.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
