Quilting - Make a Jelly Roll Rail Fence
Published
Introduction: Quilting - Make a Jelly Roll Rail Fence
About: MyHobbyStore is part of MyTimeMedia, which publishes some of the best known specialist hobby magazines in the UK including popular titles such as RCM&E, Model Engineer, Model Boats and Popular Patchwork. We ...
Use Jelly Roll strips to piece this reversible quilt-as-you-go project. Designed by Fiona Law, made by Sally Stevens and Sadie Yeomans, from an article on http://www.popularpatchwork.com/
Materials
Note that the requirements are based on fabrics with a minimum usable width of 42in
    One Jelly Roll
    2.2m (2 1⁄2yd) backing fabric
    1m (1 1⁄8yd) for front joining strips
    70cm (3⁄4yd) for back joining strips
    1.2m (1 3⁄8yd) of 90in wide wadding or use leftover pieces: minimum 10 1⁄2in square. See section 'Cutting instructions' Step 2.
Finished Size
Approx 130 x 158cm (52 1⁄2 x 63in) based on a 10 1⁄2in block
Step 1: Cutting Instructions
1.  Cut the Jelly Roll strips into 10 1⁄2in lengths – you should get four from each Jelly Roll strip. You will need a total of 150 lengths.
2.  From both the backing fabric and the wadding, carefully cut thirty 10 1⁄2in squares.
3.  From the front joining strip fabric, carefully cut twenty 1 3⁄4in wide strips across the width of the fabric.
4.  From the back joining strip fabric, carefully cut twenty 1 1⁄8in wide strips across the width of the fabric.
Step 2:
1.  Place a backing fabric square right side down, place a wadding square on top of it and then, right side up, place a Jelly Roll strip wrong side down on top of the wadding, matching up the lower and side edges with the wadding.
2.  Place a second Jelly Roll strip right side down on top of the first strip. Using a 1⁄4in seam, join on the long edge nearest to the centre of the block. Open out and press. Right sides together and matching up the raw edges, place a third Jelly Roll strip on top of the second strip and stitch in place. Continue working in this way until the wadding is covered – you will need five strips. See Figure 1
3.  Repeat Steps 1 and 2 until you have made thirty blocks.
4.  All the blocks need to be the same size and must be true squares, so trim if necessary.
Step 3: Joining the Blocks
1.  From the front joining fabric strips, cut twenty-four strips the length of your block (should be 1 3⁄4 x 10 1⁄2in). Wrong sides together, fold the strips in half lengthways and press.
2.  From the back joining fabric strips, cut twenty-four strips the length of your block (should be 1 1⁄8 x 10 1⁄2in).
3.  Right sides together and matching up the raw edges, place a folded front joining strip on the right-hand edge of a quilted block. With the right side of the strip against the backing fabric, on the same edge and matching up the raw edges, place a back joining strip against the back of the block. Stitch the joining strips in place. See Figure 2.
4.  With the block right side up, open out the back joining strip. Right sides together, place a second block on top of this, matching up the raw edge of the block with the raw edge of the back joining strip; stitch to join. Take care to orientate the second block correctly – the strip direction of adjacent blocks alternate. See Figure 3.
5.  Open out the blocks. Open out the front joining strip to cover the join and slipstitch the folded edge in place on the second block. See Figure 4.
6.  Repeat Steps 3–5 to make a row of five blocks.
7.  Repeat Steps 3–6 to make a total of six rows of five blocks.
8.  Join seven front joining strips to make one length; trim to give five pieces the length of your quilt rows (approx 52in). Wrong sides together, fold the strips in half lengthways and press.
9.  Join seven back joining strips to make one length; trim to give five pieces the length of your quilt rows (approx 52in).
10.  Join the rows together in the same way that you joined the blocks. See Figure 5.
Step 4: Finishing
1.  Join seven of the front joining strips to make one long length. Wrong sides together, fold the strips in half lengthways and press.
2.  Join seven of the back joining strips to make one long length.
3.  Right sides together and matching up the raw edges, join the back joining strip length to the front joining strip length. Open out and press. This is a split binding.
4.  Working from the back of the quilt, match the raw edge of the back joining fabric (single thickness) of the binding with the raw edge of the quilt and sew in place, folding a mitre at each corner. Before completing your stitching, neaten the short raw end of the starting piece and insert the ending piece into it.
5.  Fold the binding over to the front of the quilt and neatly slipstitch the folded edge in place on the front of the quilt.
6.  Finally, add a label to the back of your quilt, with your name and the date it was made. If the quilt is a gift, perhaps add the name of the recipient(s) and the occasion too.
Step 5: Handy Hint
If you prefer, you can make a contrasting binding by stitching the back joining fabric (single thickness) to the front of the quilt instead of the back. The front joining fabric will then be turned to the back of the quilt as a contrast.
Step 6: Smaller Version
If your Jelly Roll strips are less than 42in wide, you can make a smaller quilt of six rows of four blocks, which will be approx 105 x 158cm (41 1⁄2 x 62in).
The requirements for a smaller quilt are:
    One Jelly Roll
    1.7m (1 7⁄8yd) backing fabric – this is based on a usable width of 42in
    80cm (7⁄8yd) for front joining strips
    50cm (1⁄2yd) back joining strips
    1m (1 1⁄8yd) of 90in wide wadding or use leftover pieces: minimum 10 1⁄2in square. See 'Cutting instructions' Step 2
1.  From the Jelly Roll strips, cut 120 10 1⁄2in lengths. You should get three lengths from each Jelly Roll strip.
2.  From both the backing fabric and the wadding, carefully cut twenty-four 10 1⁄2in squares.
3.  From the front joining strip fabric, cut fifteen 1 3⁄4in wide strips across the width of the fabric.
4.  From the back joining strip fabric, cut fifteen 1 1⁄8in wide strips across the width of the fabric.
5.  Proceed as for the larger quilt, remembering that each row contains four (not five) blocks.
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
