3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Jet Powered Go-Kart
Jet Powered Go-Kart
Hi all, this is a go kart which is powered by a home-made Gas Turbine (Jet Engine), it is the result of 6 months of planning and 3 months of building. The kart and the engine was all home-made thanks to some kind people who helped me find some hard to find parts.
I do know that the engine runs, but as of today (20/Oct/11) I am not sure if it will get any decent speed and I cant find out until April 2012 as it is a fire hazard.
The Turbo Charger was $700AU
The total cost was $1600AU
Specifications:
Turbo: AI Research, 3.9 inch Inducer
EGT Running at idle: 550'c
Oil Capacity: 4.2L
Fuel start: LPG
Fuel Run:
Gasoline
Compressor Pressure idle: 15PSI
Max Turbine Speed: 65,000 Rpm
If you have any requests or questions please contact me.
I am not responsible for what ideas you may get from this page or
what damage you may cause to yourself or property.
16 comments
Mar 3, 2012. 12:49 AMThe nerdling says:
that thing is daggy but AWESOME!!!!!!
Mar 3, 2012. 3:56 PMThe nerdling says:
-if you could rebuild the big tank poking out from the jet to fit inside the chassis, that would be good
-a rounded cage at the back to house the turbo, instead of the big square one with heaps of space, might make it lighter (less metal) therfore go faster.(like the picture)
-do you mean besides the wheels as is, you know theyr'e daggy or your keeping them?
-put a good seat in because that doesn't look comfortable
-better breaking system, that won't work well if you mod it bigtime
-mabey an afterburner like lemonie said look around instructables for ideas, or watch the scrapheap challenge episode where they made jet carts, because one team made one out of a turbo like yours
-small crumple zone on the front
well that's all i could think of, hope it helps :0
Mar 3, 2012. 8:37 PMThe nerdling says:
if there will be a mk2 i can't waite to see it :)
Mar 3, 2012. 9:31 PMThe nerdling says:
Oct 20, 2011. 12:08 PMlemonie says:
Lovely.
I think it would benefit from an exhaust-nozzle, and an afterburner.
L
Feb 17, 2012. 12:42 PMjustin.d.siegfried says:
Some form of adjustable nozzle with the linkage going up to the drivers seat should work. That way it can fire up with the opening large then shrink as it speeds up.
Oct 21, 2011. 1:05 AMCatsunami says:
I like it :D I also like how it's an instructable telling you not to try it at home.
Oct 20, 2011. 9:25 PMCoffeeFreak says:
nice build, you can buy used APUs at relatively low prices (for turbine engines) that will drive anything you can hook up to a drive shaft
Oct 20, 2011. 11:27 AMKiteman says:
You can get an idea of the potential thrust by standing a set of bathroom scales on edge against a wall, resting the front of the cart against the scales and running the engine - the scales will read off the force with which the jet is pushing.
Convert the thrust into Newtons, and divide by the mass of the cart in kilogrammes, and that will give you an idea of the initial acceleration in ms-2.
(You can do a similar calculation in Imperial units, but I work in metric.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:brendonl
My name is Brendon and I live on a hobby farm in sunny Australia. My main interests are Gas Turbines (Jet Engines), High Voltage electricity and Computers.
