loading
Step 6: Finished Product
Below are a few images of the finished product. Hope you like it
could you make this out of titanium?<br /> <br />
Indeed, Ti would be kinda hard to manipulate, and also to engrave. Perhaps with more suited tools...<br>
&nbsp;I really like this idea, I'm going to try it on copper.<br /> <br />
Thanks for the tip.
I have a concern about the edges at the ends of the bracelet being sharp.(where you slip is on your arm.) Does it add a lot of bulk to turn those edges in?
yeah, that definately be too bulky. Maybe cut the bracelet to size before you bend it. Then sand all the edges until they are smooth and then do all the folding. Hope that helps :)
Could you use an used aluminium drinks can cut open and turned inside out instead of buy some?
I recommend those slim fast cans if you want to recycle. That's what I made mine out of and it works great
Aluminium drink cans are a little thin and therefore might be too sharp
Okay thanks, it just an idea 4 recycling stuff
although i'm months late, you could probably use an old coca-cola can or the like, but you'd want to bend all the edges inward, including the lengths and widths of the strip from the can, when you round it to make this bangle it may crimp but considering how little the intensity of the bends seem to be it may be okay, nothing wrong with trying
You could use aluminum flashing from the hardware store. It comes in rolls and you would have a lot of aluminum. You could make many, many bracelets!!I think I'll try it. Thanks for the idea.
inscribing it before you roll it will make the job easier
it has an expensive look to it. i like it!
Looks nice! You should add this to the Homemade Gifts contest.
Yeah I'm working on it, I'v always had problems adding projects to groups. I dont know why
You seem to have it under control. I recommend you go ahead and join the groups you're likely to file under later, then when you're making your Instructable public it will prompt you to tick group boxes at the same time it asks for keywords. That's the easy way.
oh is that how you do it. Because I couldn't find the homemade gifts group when being asked for the keywords, So you join the group before you publish your projects. Thanks, now I know how
About This Instructable
23,225views
126favorites
License:
More by puffin_juice:Sonic Control Folding Paper into Thirds I need your help. IPT (Inductive Power Transfer)
Add instructable to:
