3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar design t-square for designing solar cooker reflectors
video Solar design t-square for designing solar cooker reflectors
I tried this on a small scale model and then scaled up.
It can better be  used on a larger scale. You could also  design flat parabolic "plates"  with mirrors  on a sheet of  plywood  to make powerful mock parabolic dishes.  (In that case only one laser shining straight down is needed)
This shows  how I used it to  design the shapes of reflectors for unattended solar cooking.
(I did not know what the  shape would be  before I began.)
The design process is done by "Claymation". Little adjustments of one area at a time until the design is complete.
The clam shape has never been repeated even though it has great potential to help people in Dafur or Haiti.
The license is attribution sharealike so  you can produce commercial versions too.
12 comments
Jan 19, 2010. 8:16 AMtatay66 says:
I don't know where your getting the mylar but here's a little help for you since i like working rough designs in mylar. First get the 7mil its firm and more resistant to wrinkles. You can get it here. http://www.snomo.com/  They are reliable and friendly. You can easily fix it into shapes for things you design be aware though its not a forgiving material, thicker also makes it harder to cut. The shape you were showing is a torus, i believe you could do that with the 7mil. Its dupont mylar and very durable for this stuff at least for testing anyways. permanent is done in aluminum mirror polished sheets. If you just want a quick test get the mirror mylar from walmart camping section its used for emergency blankets. You will have to back it with something foam sheet cut to shapes you want to test. foams not expensive at about 10 dollars a 4'x8' sheet 1in thickness. Cut your pattern from poster paper first so your mylar is the correct size and shape.
Jan 22, 2010. 7:28 PMtatay66 says:
jeff_banaszak2003@yahoo.com do you have a work around for exporting wave OBJ. from sketchup it would be very appreciated.  I presently use sketchup for my designs but if you've ever tried it you know theres no mirror ruby, no light ruby and no corrected materials reflection for light. So ive been using the shadows in reverse to track the light paths for the mirror sets. I saw your video on Art of Illusion and downloaded it to give it a try my only issue is that i will have to learn how to use yet another program. Not only that but i cant get the OBJ pluggin for sketchup to work on complex geometries. Do you have a solution?? I've tried ricks ruby from the forum but it doesnt work with complex geometries. I really want to try out my designs in Art of Illusion but each one took hours to set up and draw. The calculations take time, and then getting it just right in sketchup took time. I will let you in on something i figured out though. Use a halogen spot light 1-2 million watt they emit infra-red and the beam is extremely hot so be careful what you have at the end of the mirrors. It may catch on fire. I checked out your T square i like the idea. Your use of the drafting tools is great for checking things. It helps when you can use the 45 or 90 in a graph to visualize the outcome. I like pythagorian theorem and euclid theorems for the point to point checking. With pythagorian theorem you can easily double the triangulated point to form an equalateral triangle for the straight bounce of the light at projected angles.
Dec 2, 2009. 4:06 PMlemonie says:
That's a nice rig - what did you use in the end for forming the reflector? (I had problems with the video and only watched half)
L
Dec 18, 2009. 12:09 AMlemonie says:
If I had the tools and work-space I'd be playing with these ideas, also more sun would help. I wouldn't get hung up on an apparent lack of interest, these things need to be seen by people who are interested in developing solar reflectors and there won't be many around here.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
74
Author:gaiatechnician
I am a stone mason. My hobby is making new solar cooking and gardening stuff. I have used solar heat to cook soil for a couple of years. In mother earth news in January, i read that their compost expe...
more »
