I saw Stig's version of this at the last Instructables Show & Tell. I was enraptured. I had to have one, and of course that meant I had to make one.
Materials:
- a power jigsaw. cordless is ideal; bladeless is fine; quiet motor is best. I spent about two weeks not finding anything like this in thrift stores or on eBay and finally bought a new, cheap-ass jigsaw off Amazon for about $30.
- one of those old keys you have lying around that you can't remember what it's for. brass is better than aluminum.
- a rubber foot for the bottom of a chair leg. 1 inch diameter is a good size
- Bondo or similar hard-curing filler
- Dremel with grinding tip (or metal file, if it's all you've got)
- popsicle stick or plastic spoon or some such to mix the bondo
- screwdriver of whatever sort your jigsaw comes apart with (mine took a hex wrench)
Remove these ads by
Signing UpStep 1Prep the jigsaw
It is not strictly necessary to remove any plastic as I did from around the chuck assembly, but I found it difficult to get the hex wrench in to loosen the chuck. (Chuck may be the wrong term but I mean the clamp that holds the blade.)
15
comments
Add Comment
gemtree
says:
mikeasaurus
says:
jeff-o
says:
frollard
says:
rachel (author)
says:
zachninme
says:
Weissensteinburg
says:
Add Comment
