3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Jitter Drive
Jitter Drive
Have you ever played with those little hex bugs from Radio Shack? Well now you can make your flash drive into one. If your bored just take out you JItter Drive and let it loose. It's easy and fast to do, and best of all it still works as a data storage device.
Step 1Materials
Materials
For this project you need:
  1. A tooth brush with no curve in the bristles
  2. A small button battery
  3. Thin wire, I used hobby wire 2.14 mm
  4. vibration motor
  5. A small switch
  6. Solder
  7. A flash drive
The tools you will need:
  1. Pliers, preferably small
  2. A hot glue gun
  3. A small saw
  4. A soldering iron
26 comments
May 5, 2011. 2:12 AMinhaos says:
here is a perfect solution may helps you:http://www.inhaos.com/product_info.php?products_id=29
cheers!
Jun 18, 2010. 5:56 PMac1D says:
I need some help! I am currently doing this right now ;) But, I cannot achieve to solder the wire on the battery. The battery just wont stick to the solder. What is wrong?
Mar 4, 2011. 9:09 AMJedrokivich says:
Try sanding the surface a bit before soldering and then put a small pool of solder on the surface. Tin your wire, then heat up the pool and put the tinned end into the solder and wait for it to cool.
Sep 10, 2010. 7:43 PMWin Guy says:
I'm just saying, but it's too dangerous to solder wire DIRECTLY to the battery, however there are some other ways, for example:
Electrical tape (Regular 3/4" tape is too conductive)
Battery casing
Craft glue (Make sure that the wire is touching the battery)
Win Guy
Jun 19, 2010. 3:53 PMrocketman221 says:
Try to scavenge a battery holder from something. If you heat those little button cells too long they will blow up.
Jun 18, 2010. 9:24 PMcaarntedd says:
Try scratching or sanding the battery terminals to expose bare metal. the terminals are plated to prevent corrosion. Resin cored solder should stick to the metal pretty well.
Make sure the terminal is hot enough for the solder to melt, but be quick as a button type cell will burst if it gets too hot.
Maybe stick with the tape instead.
Jun 19, 2010. 12:54 PMjaysbob says:
it's actually rosin core solder :)
Jun 19, 2010. 10:05 PMcaarntedd says:
It depends where you live. It's the same stuff, but all my rolls of solder say resin core.
Jun 19, 2010. 10:01 AMac1D says:
I have sanded the battery, and it worked just fine. I know cell battery burst, we used to put em in a toaster for the boom some year ago :)
Jun 18, 2010. 6:27 PMStormrage says:
try using soldering paste... i think it would help... or try just a bit of HCL
Jun 27, 2010. 5:19 AMTSC says:
Cool!!!!!!!!!!!
Jun 20, 2010. 1:26 PMaccount3r2 says:
It's FLASH DRIVE. A zip drive is an entirely different thing. A zip drive is like a floppy drive. Except bigger.
Jun 22, 2010. 3:22 PMsiege10 says:
i supposed bigger is the correct word as far as storage capacity goes... it really wasn't that much bigger as far as physical size went. (capacity was normally 100 megs)
Jun 23, 2010. 4:10 PMaccount3r2 says:
i meant bigger physically. not by the capacity of the disk, even though it does have more capacity than a floppy disk. thats not even on the subject. a flash drive uses usb, and zip drive or disk is big, it uses magnetics, and it is kinda out-dated.
Jun 18, 2010. 5:20 PMnaruto the ninja13 says:
what exactly is this?
Jun 19, 2010. 8:50 PMnaruto the ninja13 says:
awwww there so cute lol
Jun 19, 2010. 4:57 PMshveet says:
you should try and have it recharge via the flash drive. so that you will never have to change the battery
Jun 19, 2010. 12:59 PMKiteman says:
This would be really cool if you replaced the battery with a super-cap, and wired it up to charge the capacitor from the USB port.
Jun 19, 2010. 5:07 AMTSC says:
Cool!!!!!
Jun 18, 2010. 8:00 PMdark sponge says:
Fun, but what would make it cooler is to have a small rechargeable battery or a supercap that charges from the USB port so you never run out of fun!
Jun 18, 2010. 2:52 PMAndyGadget says:
Interesting combination of functions. How about using a rechargeable button cell and have it recharge when it's plugged in.
(Best not to use the USB stick for mission-critical data storage #;¬)
Jun 18, 2010. 5:18 PMnickodemus says:
Funny that, I thought the same thing when I saw it! Haha :D
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:robot19
