Joiners Mallet
5,466
167
6
Posted
Introduction: Joiners Mallet
I've been meaning to make a copy of this mallet for a friend for ages It's about 35 years old and was made by laminating 4 pieces of Ash together fitted round the Sliding dovetail handle.
I'm going to make it out of American white Oak with a Pine handle.
Part Required. Aprox
2 Pieces of hardwood 300x120x35 outer
1 Piece hardwood 300x120x38 inner
1 piece softwood for the Handle
Glue I used expanding Gorilla glue but the original mallet was glued up with waterproof PVA
Bandsaw or Jigsaw if using Jigsaw I suggest shaping parts before glue up.
Cut the handle to shape and plane the dovetail down to size.
Cut the inner piece in half
Step 1: Gluing and Laminating
ensure handle and laminates are the same thickness
Wrap the top of the handle with cellophane tape to stop the glue sticking to it then glue up and clamp making sure that the inner laminates are tight to the handle
Step 2: Tap Handle Out and Shape on Bandsaw
Leave overnight to set then tap the handle out of head remove cellophane and shape head on the Bandsaw and plane sand until smooth plane all corners
Step 3: Shape Handle
I used a spokeshave to put rounds on handle and then smoother with palm sander,I sealed and waxed the handle
Step 4: Finished Mallet
Finished mallet showing lamination,
I hope it stand the test of time like the Original.Check out the video
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    6 Comments
    What wood do you recommend? I was going to buy one for use with chisels, but might as well make it! I will also need to go get a spokeshave.
    beech for the head and ash for the handle.good luck
    I like the build- easier to make than some I have seen on you tube.
    Thanks for the comments, yes its a easy build just a few clamps.
    Nice build. Thanks.
