Remove these ads by
Signing UpStep 1Use a sanding drum in place of a jointer
In the graphic the sanding drum rotates in a counter-clockwise direction. The work moves over the table from right to left.
Cuts taken are very light. Flip the work over frequently so both sides of the work are staight and true when finished. When the sanding drum no longer cuts, loosen one of the "C" clamps and move that end of the fence nearer to the sanding drum only about the thickness of a pencil line. Clamp again and continue feeding the work past the sanding drum.
As you run your board against the planer board the router bit takes off however much material you took off of the one side. Make sure not to take too much off so that your router can handle the removal, which means you may have to make several passes.
Hopefully the attached image helps.
I wanted to say"nicely done," too! I have a drill press with a sacrificial plate that I drilled a big hole in so I could drop a drum sanding bit in, but instead of a single board in front of the piece - as you show here (smart!) - I tried to set up a split fence by clamping 2 boards down. I had the outfeed 'fence' flush with the front of the drum bit, and the infeed jogged back slightly. That's how I do it on the router - flush the outfeed, drop the infeed back a whisker. It was too hard to align my boards well, though, and even with some powerful Bessey Tradesman clamps, the vibration of the drill press and my pressing firmly into the fence wiggled things out of true. I got lousy results. I'll have to try your method if/when I use this technique again. Thanks for sharing!
The alert for your comment confused me, because I was just talking planes and sharpening in another forum elsewhere, and we had a similar conversation. That person wholeheartedly recommended Hack's Handplane Book. I'm going to pick it up soon.
