3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Joint Boards without a Jointer
Step 6Update: Idea in response to gfixler's comment
Update: Idea in response to gfixler\
Below is a way of using a router for jointing so the router bit cannot vibrate or jump into the work and make a cupped indentation in the work's edge. The fence (yellow) clamps to the work (brown). The router bolts onto the attachment (yellow). The attachment rides on the fence.
4 comments
Jan 7, 2010. 4:47 AMwilwrk4tls says:
 A method I used was to make a fence for my router (used in a router table) that had a hole sized for a bit, where the very tip of the router blade was tangent to the router planing fence edge.  Then I used a table saw and cut down one side of the fence (based on the rotation of the router bit) so that it was slightly shallower than the other edge.
As you run your board against the planer board the router bit takes off however much material you took off of the one side.  Make sure not to take too much off so that your router can handle the removal, which means you may have to make several passes.
Hopefully the attached image helps.
Oct 7, 2008. 10:22 PMicurays1 says:
Good instructable! I only see one real problem with the drum sanding method, being a long time woodworker. Many times when you need to joint a board, neither edge is straight. Using a fence to guide the piece through a tool will make the board parallel - not straight. So if one edge is pretty straight, you'll be fine, you can make the other edge parallel (and thus straight) The idea with a jointer is that you rely on the outfeed side (after the cutter) of the jointer to provide flatness, not the board itself. The router method you outlined works great if you go slowly, take a very thin pass, and have a straight guide piece. You can even buy aluminum clamp-on guides for just this. Another method (besides the 'ol hand plane) is to attach your to-be-jointed piece to a straight piece (with screws or cam clamps) and run it through a table saw. There's also a commercial product for this type of thing.
Sep 25, 2008. 5:09 PMhandidad says:
One method of using a router for jointing is to first fasten the 2 boards together with a gap that is just lightly narrower than the width of the router bit.. A router attachment that is fastened to a fence would be ideal for this application. The purpose of jointing the 2 boards at the same time is that any irregularities will be mirrored on the other board and then cancel out when they are glued together..
Sep 27, 2008. 5:20 AMhandidad says:
I also have not tried it. It would only be successful if the router was attached securely to a very strong guide or fence.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
476
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
