Introduction: Jollex's Sniper, JS-144v3.9
JS-144v3.9
I have finally finished my awesome sniper. I have been planning this gun since June and started building in late July. It is the first of its kind. It uses a rail system like dsman195276's sniper but it has a mag. It has a lot of power and accuracy because of the low friction barrel made out of orange connectors and wheels. It has a trigger that I think is better than dsman's sniper trigger. It has a comfy handle that is like dsman's sniper handle. It has a comfy stock a very accurate and cool looking scope. It also has a sturdy bipod of my design and a comfy front hand grip. it is also easy to pull back the firing pin.
Stats
-Mag holds 10 blue rods-Mag reload time is 8 seconds
-Time to pull back firing pin and power transfer is 4 seconds
-Weight = 1.6 kg ~ 3.5 lbs
Video
Step 1: Piece List
Piece List
I'm going to do a separate piece list for each part.Extended Barrel
Rods:Blue - 15
Green - 50
Connectors:
Blue - 14
Yellow - 14
Orange - 31
Other:
Blue Spacers - 2
Y-Clips - 2
Barrel
RodsBlue - 9
White - 23
Green - 29
Connectors
White - 8
Blue - 2
Yellow - 12
Green - 2
Red - 3
Orange - 7
Light Grey - 2
Dark Grey - 1
Other
Blue Spacers - 8
Y-Clips - 5
Big Wheels - 4
Chamber, Mag, and Power Transfer
RodsRed - 5
Yellow - 1
Blue - 7
White - 20
Green - 28
Connectors
White - 10
Blue - 4
Yellow - 17
Green - 2
Red - 2
Orange - 11 (One cut in half)
Dark grey - 3
Other
Grey Spacers - 8
Blue Spacers - 9
Y-Clips - 1
Tan end caps - 8
Metallic blue end caps - 7
Body
RodsYellow - 1
Blue - 18
White - 42
Green - 141
Connectors
White - 12
Blue - 1
Yellow - 69 (two broken)
Purple - 43
Red - 8
Orange - 15
Dark Grey - 3
Other
Grey Spacer - 5
Blue Spacers - 5
End Caps - 2
Firing Pin and Trigger
RodsYellow - 3
White - 10
Green - 6
Connectors
Yellow - 2
Red - 6
Orange - 2
Dark Grey - 2
Other
Grey Spacers - 4
Blue Spacers - 2
Y-Clips - 1
Stock
RodsYellow - 5
Flexy Yellow - 10
Blue - 7
White - 19
Green - 47
Connectors
Blue - 10
Yellow - 3
Green - 12
Purple - 32
Red - 7
Orange - 1
Other
Y-Clips - 6
Handle
RodsBlue - 2
White - 20
Green - 15
Connectors
Yellow - 12
Green - 3
Orange - 8
Light Grey - 3
Dark grey - 2
Other
End Caps - 2
Blue Spacers - 2
Very small wheels - 10
Front Hand Grip
RodsGrey - 1
Bendy Purple - 5
Connectors
White - 3
Other
Y-Clips - 10
Scope
Rods:Grey - 4
Connectors
White - 8
Red - 18
Other
Y-Clips - 42
Small Tires - 8
Black Hinge Halves - 2
Bipod
RodsGrey - 5
Blue - 6
White - 2
Connectors
White - 1
Red - 2
Orange - 6
Dark Grey - 6
Other
End Caps - 1
Blue Spacers - 4
Y-Clips - 8
Hinges - 2
2 Big Rubber Bands1 Small Rubber Band
Whole Gun
Rods
Grey - 10Bendy Purple - 5
Red - 5
Yellow - 10
Bendy Yellow - 10
Blue - 64
White - 136
Green - 316
Connectors
White - 43Blue - 31
Yellow - 129
Green - 19
Purple - 75
Red - 28
Orange - 81
Light Grey - 5
Dark grey - 17
Other
Grey Spacers - 19Blue Spacers - 28
End Caps - 19
Y-Clips - 63
Big Wheels - 4
Very Small Wheels - 10
Small Tires - 8
Black hinge halves - 2
Hinges - 2
Big Rubber Bands - 2
Small Rubber Bands - 1
Step 2: Extended Barrel
1:Make
2:Make
3:Add
4:Make
5:Make
6:Add
7:Make
8:Add
Step 3: Barrel
1:Make
2:Make
3:Get
4:Connect
5:Make
6:Add
7:Add
8:Make
9:Add
Step 4: Chamber, Mag, and Power Transfer
1:Make
2:Make
3:Make
4:Add
5:Add
6:Make
7:Add
8:Make
9:Make
10:Connect
11:Make
12:Make
13:Make
14:Connect
15:Make
16:Add
17:Make
18:Add
19:Add
20:Make
21:Add
22:Connect
23:Connect
Step 5: Body
1:Make
2:Make
3:Connect
4:You have to break two yellow connectors so they look like this.
5:Make
6:Make
7:Make
8:Make
9:Make
10:Connect
11:Connect
12:Make
13:Connect
14:Connect
15:Make
16:Connect
17:Make
18:Connect
19:Make and Connect
20:Connect
Step 6: Firing Pin and Trigger
1:Make
2:Connect
3:Make
4:Make
5:Connect
Step 7: Stock
1+2:Make
3+4:Make
5:Make
6:Connect
7:Connect
8:Make
9:Add
Step 8: Handle
1+2:Make
3:Add 10 wheels
4:Make
5:Add
Step 9: Scope and Front Hand Grip
1:Make
2:Add
3:Make
4:Make
5:Connect
6:Connect
7:Add
Step 10: Bipod
1:Make Two
2:Make
3:Make
4:Make
5:Make
6:Connect
7:Connect
8:Connect
Step 11: Putting It Together
1+2:Extended Barrel and Barrel
3+4:Barrel and Chamber, mag, power transfer
5+6:Chamber, mag, power transfer and body
7+8:Front Hand Grip and Body
9+10:Handle and Body
11+12:Trigger and Body
13+14:Stock and Handle and body
15+16:Scope and Body
17+18:Bipod and Chamber, mag, power transfer
19+20:Firing Pin and Body
Step 12: Rubber Bands and How to Use
1:Rubber Bands
2:Trigger RB
3:Firing Pin RB
4:Put Bullet in mag
5:Pull back Firing Pin until the front blue metallic connector is in the space of the orange trigger connector
6:Pull string back on Power Transfer
7:Aim
8: Pull Trigger
Step 13: Destruction
My parents were not happy about the lamp.
