This project is basically a "Joule Thief" but with more scrap parts reuse and unfortunately less efficiency. The basic Idea is to use the core of a motor as both the "toroid" part of a "joule thief" (with the rest of the circuit concealed in and around it) and as a nice light reflector (which , if you have access to a pancake motor, is conveniently reminiscent of a flower or the sun).
As previously stated it is very inefficient, and the reason I chose to do it this way is that it uses an otherwise scrap part as a functional and decorative component. Obviously, if you so choose, you can put a hand wound toroid
For a few more pictures and discussion please see my blog post
Remove these ads by
Signing UpStep 1Bill Of Materials & Equipment
1 x 1k resistor
1 x NPN transistor (the 2N3904 is adequate, however 2N4401 or PN2222A will give better light output)
1 x LED
- x Enamled Copper Wire (0.315mm is fine)*
1 x Reasonably sized electrical motor. DC and stepper motors are both fine.
*(other insulated wire should work fine, I used this and it looks OK)
Equipment
Soldering Iron & solder
Needle Nosed Pliers/tweezers
Screw driver
Ohmmeter/Multimeter
The range of stepper motors in even one computer (floppy (2 motors), CD drive (2 motors), Hard drive, case fan, CPU fan, power supply fan) is quite surprising, it was due to having an over abundance of old computers' mismatched motors that I became interested in reusing them for something.
My favourite stator is found in laptop CD drives - it is a small, flat pancake stepper that works very well with the joule thief circuit, and makes a compact and very flower like device.
With regard to your other comments, thanks for the terminology corrections. As previously noted I have been unable to find any consensus on the names of the variously structured stepper motors - I just made some names up because in this instructable they only serve as points of reference to aid hacking. I do appreciate terminological corrections and think that they are useful as comments.
One thing to note is that comments don't attach to a single step, only to the instructable. It's clear from your messages what you mean, but just for future reference that's how Instructables lists comments (that confused me a few times when I joined too).
Thanks,
Andy
Thanks again,
Drew
I am looking for more disk drives to do just that but they are kind of hard to find in Hawai'i cause everyone has the latest of everything here it makes me sick.
When I find the next drive I will take the thing apart more carefully. The screw that holds the disk that holds the magnets has Lefthand Threds. Hindsight is 20/20.
I will be very interested to know when the strip magnet is replaced with more powerful tiny magnets from harddisk drives, how much electricity I can harvest from such a tiny stator.
If your looking for a small generator there are many alternatives to floppy disk drives - anything broken with motor actuated parts (personally I have reused motors from toys(dc), motors from printers, scanners, record players, walkmans, tape players, CD and DVD drives, servos and many others). Hard drive disk motors are very well made and well worth scavenging. If you find anything broken and electrical it is rewarding to take apart, if for nothing else than to see how it works, and how it's made.
I too have come across counter intuitive things like "backwards" threads and 3 spoke Philips heads, and other puzzling design decisions. The hardest dis-assembly that I have done was a (broken) office laser printer, which had multiple concealed redundant retaining clips and screws.
I have wanted for a while to make a mini portable generator, possibly a VAWT (Vertical Axis Wind Turbine) and it's low down (getting higher) on my "future projects" list.
Regards,
Drew
Thanks! Yeah I had trouble with the terminology, in that I found lots of names for different connection graphs. In the end I just made up some names for the various topologies based on how they look - I figured that it would be easier to understand if I just gave each a name and stuck with it.
Thanks for your input,
Drew
Easier to wind than a toroid, nice post.
L
Other shielded wire?? I think you meant insulated wire.
I think your right about swapping out the 2N3904 for something beefier, but I can't see having four transistors in parallel being very good looking, the problem of holding components in place becomes more of an issue if you are free forming. Having said that if it makes it work it makes it work.
Drew
Thanks,
Drew
