3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Joule Thief Battery Charger
Many of you are probably aware of the "joule thief" circuit. If you aren't, it's a very simple voltage booster that is normally used to power an LED off of a mostly dead AA battery, but it can be used for other applications where a voltage boost is needed. One such application is charging a battery off of a battery with a smaller volatge rating. There are designs out there for battery chargers using a 9 volt battery and then step down the voltage to the level of the battery to be charged. But this circuit uses any single battery with a rating of 1.5 volts, such as a AA, C, or D battery, and bumps the voltage up to a level that can charge a battery with a voltage rating of 5 volts or lower. This curcuit is extremely simple, dirt cheap, and can be built in an afternoon using parts taken from other old devices.
Step 1Parts and Pieces
Parts and Pieces
Parts for the charger include:
2N3904 NPN transistor
1K ohm resistor
Toroid transformer core
Magnet wire
Diode
SPST Switch (not pictured)
A word about some of the parts:
The toroid core can be any size, but nothing fancy or big is needed. A small toroid is probably better just because it is more compact. Only one toroid is used in the circuit, but two are pictured for size reference.
The diode can be just about any diode, but the lower the forward voltage drop, the better. Germanium diodes work the best. To find the forward voltage drop, simply hook a diode up to a battery, and measure the difference in voltage with and without the diode in the circuit. If the voltage drop is about equal to the voltage being supplied, make sure the diode isn't hooked up backwards.
17 comments
Apr 11, 2012. 2:18 AMechuzzzzcute says:
what diode you are using ?
Nov 30, 2011. 3:35 AMfjohn says:
is it ok if i use the big toroid?
Dec 1, 2011. 2:39 AMfjohn says:
how many windings? and can i use normal wire like abt 3mm thick its thicker than urs and doesnt look pretty after winding and tried the whole thing with the ciruit and it doesnt workhelp!!!!
Aug 30, 2011. 8:22 AMerror32 says:
I would be interested to see you measure the charging current here
Nov 8, 2011. 4:00 PMionic says:
Provided you keep the voltage above the charging batteries nominal voltage and 13mA is constant, how many dead AA's would it take to charge another AA battery? For a 2000mAH AA battery with 200mA charge current it will take 12hrs - 14hrs to fully charge it. At 13mA charge current it will take you roughly 15X as long
and you will need a hand full of batteries to do it as well.
The circuit works nice for a White LED power source, but I would rather call the device in this configuration more of a Trickle Charger, if that. Do you have any data on how long it takes to charge a particular battery and how many dead AA's it takes to do the job?
Oct 15, 2011. 4:38 PMlden hartog says:
cool! could you post a video on youtube? and whats ther current draw fro the battery? i was thinking about using a tree battery and this circuit to make tree lights :D
Oct 18, 2011. 3:14 PMlden hartog says:
a tree battery was something i found on the internet. pound a few pennies into a tree and parallel them, and parallel galvanized nails a foot lower on the tree. i get about .3 volts off of it, and i thought if i put some in series, i could make tree powered walkway lights! lol that would be just hilarious!
Oct 18, 2011. 4:30 PMlden hartog says:
thts what i was gonna do. but... maybe one joule theif to get tree up to 1.5 volt for battery, and another to get it to 4.5. my walkways are really weird anyway, and ther not very long O.o
Sep 4, 2011. 7:22 AMMunchys says:
I wanted to put a solar panel to charge batteries and when it becomes night the batteries light up the leds :D For those little things outside around walkways
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:JoeBeau
Why fix it if it ain't broken? Cause it's fun!
