3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Joule Thief Charger
Joule Thief Charger
Let your dead battery give life to another! An open circuit Joule Thief can put out 50 or more volts. Enough to charge a AA or AAA Nicad or NiMH rechargeable battery.
Step 1Make the Charger
Make the Charger
Use this schematic to build a standard Joule Thief circuit with the added diode.
My joule thief uses twisted network wire passed through a small ferrite core. I use 6 turns of wire. You can find a core from a burned out compact fluorescent bulb. You can see how others have wound the coil and built the Joule Thief, since so many have done so. Just add a diode and LED in series with the charging battery. The LED is useful as a charge indicator.
A high-speed schottky diode would be the most efficient. The 1N4005 was handy at the time and works.
70 comments
1-40 of 70next »
Dec 6, 2011. 7:34 PMblinkyblinky says:
How many turns go BEFORE the 6 turns?
Dec 7, 2011. 8:17 AMblinkyblinky says:
So technically If I wond 30 turns would it make any difference?
Dec 8, 2011. 12:45 PMblinkyblinky says:
Thanks. On my digital meter, when I measured and checked for voltage I got 0.1 volts less than the battery had. What happened?
Dec 1, 2009. 5:44 AMnamzer0 says:
how much is the current draw? when not charging/open circuit and when charging?
Dec 6, 2011. 11:12 PMmitchiko says:
You cannot measure the current draw in the open circuit only the voltage.
Nov 7, 2011. 9:56 AMfreenergyfuture says:
I am very interested in Joule Thief's and i am curious how to place a variable ohm resistor into the circuit? please reply asap.
Oct 31, 2011. 4:08 PMagatornz says:
i like the idea of this for hiking - using a combination of nimh rechargables and alkalines for my electronics - it would be great to be able to charge the former - is there some way you can include a simple "charge level indicator" in the circuit so one would know how well charge the rechargeable is?
Apr 21, 2011. 11:31 AMtwighahn says:
can u put this in layman's terms?
Mar 17, 2011. 11:31 PMab3t says:
What if the batteries have a voltage of 3.7 volts used? What should be changed?
Feb 18, 2010. 6:46 PMmikedoth says:
Stupid question but why doesn't the LED blow from the high voltage alone?
Mar 4, 2010. 1:07 PMSwingNoob says:
because your using a 1k resistor as well
Mar 4, 2010. 3:34 PMmikedoth says:
I'm still learning but will a 1k resistor drop 52.6 volts down to 1.5 to charge the battery? How about a voltage regulator?
Feb 18, 2011. 3:03 PMleodahsan says:
more like a constant current source? ;)
btw.. what are better options than the 2n2222? I need something that generates 40v @ 20uA (the more the better ;P) from anything around 1 to 3.4v. Anything in this range, but I don't know how to start..
Jan 3, 2011. 3:31 AMknektek says:
is this like a campain for charging up batteries. 'All dead batteries please save a ni-cd's life today and donate 500 milli amps each month'.
Dec 23, 2010. 9:45 AMdasimpson1981 says:
so hwne the battery is charge dose the led go out ?
Dec 19, 2010. 5:15 PMdasimpson1981 says:
i have tried this and well the charge is false the voltage is right but there is never any ampage to run anything i have tried charging then running down over and over and dose not seem to improve or work
Sep 13, 2010. 12:46 AMCyborgGold says:
you should have done this logging with the rechargeable battery starting out dead... this one just hovers at full charge... actually it appears to drop slightly in charge.
Jun 16, 2010. 11:16 AMflying pie says:
circuit is too small and can u add a solar panel to the "charge donor " so u can charge it without using up a battery to charge a diffrent battery
Sep 12, 2010. 7:47 PMA good name says:
Are you serious? The circuit is too small? Adding a solar panel would defeat the purpose. You're using a next-to-dead battery to charge another battery.
Sep 6, 2010. 7:44 PMtinstructable says:
You know you don't need that diode... the led is acting as a diode. Light Emitting Diode. Just a tip.
Apr 23, 2010. 8:39 PMelectrofreak says:
What is the frequency range for these types of circuits?I'm curious because if the frequency is high enough a fast type diode could be a better choice. Also it will help in determining the size of the capacitor if one decided to filter the output.
Apr 11, 2009. 10:18 AMlolzertank says:
Wouldn't the led eat up a lot of power? Assuming that its a red led (2v), then the total load is 0.7v (diode) + 2v (led) + ~1.3v (battery) = 4v * (your charge current). Without it, it would be 2v * (your charge current) total, increasing the efficiency dramatically. Of course, since you're using dead batteries, this might not be important at all.
Apr 1, 2008. 12:00 PMwebmasterpdx says:
 Shottky diode shouldn't be .7V. Probably could use a germanium too. Either gives you capability of working with lower input voltage. personally, I'd get rid of the LED too (maybe have a pushbutton to see if it's working. You could also pass it through a capacitor to remove the DC component and the try a full wave rectifier. Might get better results....I'm not sure.
Mar 19, 2010. 7:22 PMyourdiyguy says:
I am not able to get this kind of voltage out of my JT what could i be doing wrong? My meter always shows the around the same voltage of the battery I am using. I am able to get the LED to light up. Could it be the type of meter im using?
Mar 20, 2010. 10:23 AMyourdiyguy says:
thanks for the help. i have been pulling my hair out trying to figure out what was wrong. im new to electronics and projects like this get me learning alot really fast, sometimes i get lost : ) so thank you. i now have a reason to buy something new, ha.
Sep 30, 2009. 9:45 PMimakethings says:
can i charge my nokia 3.6v Li-ion battery with this?
Nov 23, 2009. 6:28 AMironsmiter says:
See the reply's to derbert, below.
Short answer, NO!!!!!!!
Long answer... you can use a joule thief to supply power to a Li-ion charging circuit, but not to the battery directly. Initially, it's just wildly reckless, but once cell voltage rises to over 4 volt, it becomes Russian roulette, with a fully loaded revolver. the battery WILL be destroyed.
Aug 5, 2009. 5:23 AMderbert says:
can i charge a 7.2v 200mAh LiPo with this?
Sep 30, 2009. 1:00 PMRe-design says:
No.
Aug 23, 2009. 10:11 AMlilpepsikraker says:
You need a 7.2 donor battery with a charge. LiPo batteries need a smart charger, you don't want your house to burn down. A $50 charger saves your house.
1-40 of 70next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
68
Author:botronics
I like to tinker and experiment with electronics, robotics, programming, and photography
