Joule Thief LED Night Light - Kit assembly step by step by ledartist
Thank you so much for purchasing the "Joule Thief" LED Night Light Kit.
Now that the kits are shipping, I want to provide "Step by Step" pictures of the assembly.
  1. Start with the resistors. Cut the leads in half (makes the soldering easier), and bend the leads. I use a small screwdriver to round the bends.
  2. Insert the resistors into the corresponding holes of the PCB. Make sure that they are in the correct positions. (The picture should help identify the color code.)
  3. Flip the PCB and solder the resistor leads. Trim the excess leads.
  4. Insert CdS sensor into PCB and solder, then trim the leads.
  5. Solder the 50k ohm trimmer pot. (Ignore the extra hole - that's there to accommodate different styles of pots.)
  6. Keep soldering the rest of parts.
  7. LEDs have polarity. Observe the flat side of LEDs to align with the markings on the PCBs. Anode (longer lead) goes to the right, looking from the front of PCB.
  8. Battery clips snap into the holes from the bottom side of the PCB. Might need some force to snap them in. Solder them.
  9. Done!
Take a moment to make sure that everything is in the correct place, and in the correct orientation. Then insert a battery and take the Night Joule Thief to a dark room. LEDs should light up.
Adjust the trimmer pot (VR1) so that the LEDs turn on at the desired darkness (as necessary).
I think that the assembly is quite straightforward, but please let me know if you have any questions or have difficulty assembling.
raysfine058 says: Oct 23, 2011. 10:30 AM
I am new to electrics and having purchased your kit I note it does not show which way I am to install the LED? I understand that: LEDs must be connected the correct way round, the diagram should be labelled (but yours is not) a or + for anode and k or - for cathode. Also as the 470uH(L1) has + & - is there a correct way to install this? Thanks.
Ray.
Feature Comment
ledartist says: Oct 23, 2011. 10:04 PM
Those LEDs have a flat side indicating Cathode. Cathode goes to the left and Anode (longer lead) goes to the right, looking from the front side of the PCB.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
