Introduction: Journal Making
These directions will produce a single 8.5" x 11" journal with a card stock cover and 40 5.5" x 8.5" plain paper pages.
Materials:
One 8.5" x 11" card stock (very thick card stock may be difficult to sew through)
Ten 8.5" x 11" plain paper pages (I printed 0.5 pt gray lines spaced 11/32" aka Wide Ruled across both sides of the paper)
Ruler
Scissors
Sewing machine
Optional materials (see the last step)
One 8.5" piece of thin ribbon for bookmark
One 8.5" x 1" piece of card stock for scalloped edge
One 8" square piece of card stock for pocket envelope
One 2" piece of 3/8" width black elastic
Label paper for QR codes
Copper foil tape, surface mount LEDs, and flat cell battery for paper circuit
Bone folder
Step 1: Fold the Card Stock
Choose a piece of rectangular card stock to be the cover. Fold it in half by bringing together the two shorter ends. Unfold the cover.
Step 2: Fold the Plain Paper
Take a stack of 10 lined pieces of plain paper and fold the stack in half by bringing together the two shorter ends. [If using paper with 5 B's wordle, place the stack with the 5 B's face down. That way when you fold the stack the 5 B's will show on the first page.] Unfold the paper.
Step 3: Assemble the Cover and Pages
Place the cover with the decorative side face down. Place the plain paper stack on top of the cover, making sure that the edges line up.
Step 4: Add a Bookmark (optional)
Cut a piece of ribbon about 8.5” long (the length of the short side of the cover). Place one inch of the ribbon against the crease at the top of the cover under the plain paper. If the ribbon has a decorative side, make sure it is face down. Tape it down with a small piece of scotch tape to hold it in place before it's sewn into the journal.
Step 5: Stitch the Binding
Use a sewing machine to sew along the center of the plain paper and through the cover. If using a bookmark, be sure to keep the extra ribbon to the side to prevent it from getting caught.
*Be sure to sew just beyond the top and bottom edges of the cover to make sure the binding goes through the entire cover and all pages. Trim any lose threads with scissors.
If you don’t get a chance to sew your binding, use a paper clip to keep your journal together for now.
Step 6: Personalize
Write your name at the top of the cover or the top of the first page of the journal. Decorate the front and back covers as desired.
Step 7: QR Code
Place a QR code label on the first page of the journal. The QR code is a shortcut to http://tinkertime.markdayschool.org.
Step 8: Accessorize (optional)
Choose a piece of square cardstock to make an envelope from. Follow the printed “Folding Diagrams” instructions or view them here. After step 6, tape or glue the right flap onto the left flap.
Some ideas for accessorizing the journal are:
- Add a scalloped edge
- Cut a piece of cardstock (solid color or decorative) to 8.5" x 1" (or narrower/wider depending on your preference) using paper edger scissors. Glue the cardstock to the front cover along the right edge.
- Create a pocket envelope
- Cut a piece of decorative paper to 8" square. With the decorated side face down, follow these instructions. Glue the envelope to the inside of the back cover near the center. Better instructions with videos: http://www.wikihow.com/Fold-an-Origami-Envelope. Better instructions with pictures: https://www.instructables.com/id/Mini-Origami-Envelopes Or here:
- Glue a loop pencil holder to the journal
- You'll need a 2" long piece of 3/8" wide elastic. Follow this video. I find that it works best to glue the elastic loop to the cover so that the pencil is as close as possible to the edge of the cover. Otherwise, the pencil becomes quite loose.
- Add a bookmark
- (See Step 4)
- Add a paper circuit.
