Step 2Pattern making and tracing
Because everybody's feet are different you are going to have to decide who to make these Joy Slippers for.
This Instructable will only go through the steps of creating the right slipper. The left slipper is exactly the same, except you will have to turn the stencils upsidedown.
Trace your right foot onto a piece of thin cardboard or thick paper. Before cutting out the tracing draw a tongue-shaped tab that sticks out from the heel about 5cm (see pictures). We will call this the tongue and it will be where we attach the slippers to the electronics later on.
Now cut out the tracing with the tabs. Put your foot back on the tracing and find the areas where:
1) your heel presses
2) the balm of your toes press
In these areas you will want to draw a strips of 1.5cm wide and at the toes: 6cm long and at the heel: 4cm long. Make sure these strips do not come within at least 1cm of the edge. Cut out the insides of these strips and make markings every 1cm along the lengths. In the next step these strips will make sense.
Tracing onto neoprene
Trace these stencils on to the neoprene twice for one foot. And mark everything as shown in pictures.
Tracing onto ex-static
You do not need to make a separate stencil for the ex-static, unless you plan on making more than one pair of slippers.
Trace the foot stencil onto the ex-static and cut it out about 5mm smaller all-round. Do not include the tongue.
Tracing onto stretch material
Unless your foot is exactly the same size as mine (European 39) then you will have to alter the pattern as seen in picture. You can also sew on a pair of socks and save yourself some time.
Add Comment
