Step 5Making connection to Arduino
Of course, if you know what you are doing, you can hook the slippers up to any other circuit or device you have for making use of their variable resistance. So if you don't intend to hook the Joy Slippers up to the Arduino, then you can skip this step.
The connection from the slipper consists of:
- Two male telephone jacks coming from the slippers
- Two female telephone jacks that will be attached to the Tupperware box
- Inside the Tupperware box the Arduino inputs will connect to the back side of the female telephone plug socket and there will be a small circuit that puts a 10K Ohm resistor between each input and the ground.
Dismantle
We need two female telephone jacks. You can dismantle a telephone jack adapter for this. You might want to clip the wires sticking out at the back to about 5mm length so that they don't come so close to each other.
Cut holes
You need to cut three holes in the Tupperware box. Two for the female telephone jacks and one for the USB Arduino cable. Use a cutter or a drill and be careful.
Solder
1) Follow semantic and solder rainbow wire from headers to perfboard with resistors, to more rainbow wire.
2) Poke the ends of the telephone wire out through the hole of the box and solder them to the female telephone jacks according to the semantic.
Superglue
Once the female jacks have been soldered you can superglue the jacks to the box to make them sturdy and relieve all strain from the wires.
Decorate
Now the box is finished and you should decorate it if you can.
Add Comment
