How to Make Juggling Sticks
47,573
71
16
Published
Introduction: How to Make Juggling Sticks
These are most commonly known as devil sticks or juggling sticks and sometimes called flower sticks.
The reason they are known as devil sticks is that when you get good at tricks, it looks like the sticks are moving by magic, and therefore "the work of the devil." It's all about illusion.
Juggling Sticks are a lot of fun to make and play with, and suitable for kids (every make is a great opportunity to teach children how to use tools safely as well as developing confidence and skills, spending quality time together and encouraging curiosity, independence and knowledge about how things work).
Cost: under $4 per set. (That's New Zealand dollars, works out at around 2.50 Euro, 2 Pounds or $3.25 US)
You can see another way of making these, with different materials here thanks to origamiwolf.
A couple of videos (not mine): simple tricks anyone can pick up in half an hourfancy pants performance sticks (skip to 1.39 for interesting stuff; don't play with fire without proper training/supervision, and don't play on train tracks. /endpublicserviceannouncement).
Step 1: What You'll Need
Sticks (2 short, 1 long) - I've used bamboo as it is incredibly cheap and an environmentally sustainable product. I got this green bamboo from Bunnings Warehouse (NZ). [15x 90cm green bamboo stakes, $7.28 - I got four sets of juggling sticks from 6 stakes, the rest will be used in the garden] I think it's better to buy the longer sticks and cut to size, as the longer ones tend to be thicker. I'd say 8-12mm thickness is best. Some people prefer dowelling as you can get a more uniform thickness and the sticks will be perfectly straight. That will put the cost up. You can use wood, metal, plastic, etc - if you've got something suitable lying around, test it out and see how it goes. My handsticks are 36cm long, the throwing stick is about 48cm long. You can make them any size to suit. Thicker, heavier sticks will move more slowly (great for beginners).
Grip - Recycled inner tubes from bicycles - in New Zealand, you can go to any cycle shop and ask them for old inner tubes they no longer want, they're usually happy to get rid of it.. 3 long thin strips about 10mm wide and at least 1m length, and 2 short wide pieces about 210 x 100mm.
Scissors
Insulation or electrical tape
(colours are purely for aesthetics - the rasta yellow/red/green is popular)
Staple gun and staples (or tacks)
Hammer
Step 2: Attach the Grip
Use the staple gun (or hammer and tack) to attach one of the long thin strips of grip to the end of one of the hand sticks (see picture).
Do not attach it too close to the edge of the rubber piece, as you will be pulling it tightly and you don't want it to pull out from under the staple.
Use the hammer as necessary to ensure the staple is secure.
Step 3: Wrapping the Grip
Stretching the inner tube tightly, wrap the grip around the end of the stick once, then change the angle to make diagonal stripes all down the stick. With children, this is most easily done if an adult holds the rubber taut while the child turns the stick. It is important that the rubber is stretched, or it will slip from the stick and not proved the grip necessary for juggling.
When you reach the end of the stick, wrap the rubber around the end once, then change direction again and travel back up the stick, the new stripes will make a criss-cross pattern. In the last photo, you can see yellow between the rubber - this is duraseal (cover seal) - I cut a strip about 4cm wide and stuck it to the stick before wrapping the grip around it. The hand sticks of the yellow set are wrapped differently - just leaving no gaps and overlapping the inner tube as you wrap it. This uses more tubing, and is purely for aesthetics - it makes no difference to the performance of the sticks.
When you reach the top again, give it a final wrap around and staple securely.
Cut the excess tubing off, but not too close to the staple (when the tension is released, the rubber might slip through the staple if it is cut too close).
Step 4: Finishing the Handsticks
Cover the staple using electrical tape. Stretch it slightly as you wrap to ensure it stays on (loose tape will come off more easily).
Do the same to the other end if you wish. Use as many colours as you like - I've just used a single red strip here. In other photos you can see I've used blue, and a combination of yellow-white-yellow.
Repeat steps 2 and 3 for the second handstick, and apply tape to match (or not, your choice).
Step 5: Wrapping the Throwing Stick
Because we are putting tassels or flowers on the ends of the throwing stick, we don't need to wrap it all the way to the end. Start about 20mm or 30mm from the end of the stick and wrap in a similar way to the handsticks.
Prepare the tassels by cutting strips half way into the larger pieces of rubber as shown in the photo. The more strips there are, and the thicker the rubber used for this part, the more air resistance will be produced and the slower the stick will spin (use thick rubber and cut thin strips for beginners, lighter-weight rubber and thicker strips for a faster spin. The pros tend to use sticks with no tassels, and often a throwing stick that is tapered to a narrow point in the middle with thicker ends, which spin really fast).
Attach the solid part of the rubber to the stick with two staples, again not too close to the edge of the rubber.
Wrap it tightly around the stick. If children are making the sticks, this is the part where adults may need to step in, as children may not have the strength in their hands and fingers to pull it tight enough. If it is loose, it will slip off the end of the stick while you play.
Staple closed and wrap with tape, then do the same at the other end.
Step 6: Find the Balance Point (optional)
The finishing touches:
Balance the throwing stick on one finger to find the balance point (should be near the centre of the stick). If you like, you can mark this point with a piece of tape. This helps as a visual reference when playing and learning tricks.
You can also put a small rubber band (or a cross section of a small tire) around each end of the throwing stick. That way, when you're not playing, you can keep all three sticks securely together in one place.
Enjoy!
This is my first instructable, so let me know how I can improve it, and feel free to ask any questions.
2 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Pets Challenge
    Pets Challenge
  • Oil Contest
    Oil Contest
16 Comments
ive played for around 25 yrs made one pair with friction tape worked but not like they should have, store bought pr i have now are 17 yrs old and wrap is shot my youngest plays and loves it im going to make me and her a set like this and try them, going to buy a set of fire sticks though been itching to play those. tks muchs for the tut
This is fantastic! I was telling my girls about these and we will make a few sets to play with.
Very well written and great pictures!
anyone on here know how to shape a wooden dowel down to a narrow point in the center as he mentioned?
OMG i love this!! Thank you so mutch for making this instructable
haha. were gonna make these at school. yay. lol.
Thank you for sharing this! My niece has recently fallen in love with juggling sticks, and my husband and I were trying to figure out if we could make her a set. I think we maybe able to make it happen now hat I've seen this!
Thank you for the tutorial, ill be making a pair of this as soon as I get what is needed :) greetings from Venezuela
My collection, for now. Can't wait to build more! Thanks for the ideas.
We are lucky enough to have a really nice hobby shop that supplies a lot my projects. If you don't have a hobby shop nearby than the local hardware store should have what you need.
For you pro 'stickers out there I would recommend aluminum tubes for the sticks as a lighter more fast moving option. The inner tubes are a really good idea, I was originally trying to get surgical tubing onto my sticks. You have definitely made my life easier.
Glad you like it. Where do you source your aluminium tubing?
Really nice - I have a set that I bought at a country fair and got pretty good with them, but I always wondered if I could make them. Thanks for showing how it is done.
I've often thought about making some of these over the years. Great job these look good.
Nice instructable! The staple gun is a great idea - certainly easier than messing around with a hot glue gun!
