There are two ways to make juice concentrate from fruit. They depend on the type of fruit you are using.
For wetter, easily juice-able fruits, go to Step 1: Frozen Concentrate. Good for oranges, lemons, many other fruits if you have a juicer.
For fruits that will be a pain to juice, go to Step 2: Boiled Concentrate. Good for berries, pomegranate, apples, pears, etc.
The method of freezing is based on the fact that juice can be extracted from ice- if you've ever made a fruit juice popsicle and sucked on it too hard, you remember that you sucked all the flavor out and had a pure ice-sicle left on the stick! Here's how to use that.
- Juice your fruit by any method- a hand juicer, a lime squeezer, by hand, into a freezer-safe container.
- Freeze it. This might take a while.
- Set up a container that can hold all of the juice with a narrow funnel on top. Upend frozen juice on top of it.
- Let sit at room temperature while the juice drips out.
- When the ice is sufficiently clear/white, you're done! Throw out the ice and keep the concentrated juice.
- Repeat freezing/thawing as necessary.
I juiced about 17 oz. of orange juice, and by repeating the freezing/thawing method described above twice, condensed to about 10 oz. It's much stronger tasting and thicker in consistency. You can also see a darkening of the color (the photos are in order).
Essentially, the idea is to get the juice out of the fruit by boiling the fruit to a pulp. The heat denatures the proteins, releasing some of the sugars (and flavor) into the water. The water then boils off as steam.
- Wash, peel, and slice fruit as necessary. I only washed the blueberries; picked the seeds out of the pomegranate, washed and sliced the strawberries.
- Put the fruit in a pot; add water to just cover. This is so that you don't accidentally fry your fruit.
- On medium heat, bring to a boil (uncovered).
- Boil at least until the fruit is mushy pulp. Boiling longer will reduce water content, but may alter the flavor of your concentrate.
- Strain pulpy fruit sludge. I used a sieve and then a cheesecloth.
The pack of blueberries shown yielded about one cup of concentrate. Four manilla mangoes made a comparable amount. The pomegranate made 1/4 cup at best. The strawberries came out to around two cups.
Step 3: Concentrate!
Fruit concentrate can be stored and frozen for future use, mixed with water to be drunk as normal juice, used as a flavoring agent in drinks- or anything else you think of! I made mine for use in Fruit Gummies.
Penolopy Bulnick
says:
Jul 11, 2012. 2:39 PMReply
HollyMann
says:
Jun 28, 2012. 8:16 AMReply
Not Nice
Visit Our Store »
Go Pro Today »
