Introduction: Jump Start Your Car With a Cordless Drill
Picture of Jump Start Your Car With a Cordless Drill
Have you got one of those cordless drills sitting around that hardly get used. If it's a 12 Volt version then , with this simple modification you can Jump start your car when you get a Flat battery, or just use it as a portable power pack.
Step 1: Simple Modification
Picture of Simple Modification
Start by removing the screws that holds the battery pack together and remove the cover.
Find a suitable place for a connector and cut or drill a hole to suit the connector.
Solder a wire to the Positive and Negative of the battery Pack then ,run these wires to the connector.
screw the cover back on and connect the Jumper Leads. You now have a 12 Volt portable Power Pack,
That you can Jump Start your Car with.
wood doctor (author)2016-03-09
brilliant ible and a money saver
livichris (author)2016-03-03
think my car battery kicks out 500 amps CCA!
Mutt Man (author)livichris2016-03-03
My Car Battery has 540 amps CCA.
Mutt Man (author)Mutt Man2016-03-03
You can always buy one of these:
https://www.tryminimax.com/apgminimax/8.0000/index.dtm?otsrid=ed4c18fa-49e7-4c99-a3a6-2fdd8fa76470
JoseM163 (author)Mutt Man2016-03-06
The widely used cobalt-based lithium-ion has drawbacks; it offers a relatively low discharge current. A high load would overheat the pack and its safety would be jeopardized. The safety circuit of the cobalt-based battery is typically limited to a charge and discharge rate of about 1C. This means that a 2400mAh 18650 cell can only be charged and discharged with a maximum current of 2.4A. Another downside is the increase of the internal resistance that occurs with cycling and aging. After 2-3 years of use, the pack often becomes unserviceable due to a large voltage drop under load that is caused by high internal resistance.
ThomasK19 (author)Mutt Man2016-03-04
Like this one: https://www.youtube.com/watch?v=9-nezImUP0w (it's German but you can turn on English sub-titles)?
doo da do (author)2016-03-06
My neighbor used a lawn mower battery to start his car all summer. Just would not hold up in the cold. One third the cost. Just be sure it will not move around. He has an older cavalier. I thought he was kidding around.
nehmo (author)2016-03-04
A better "trick" is to use a Lithium Polymer battery. The specific energy (Wh/kg) is much higher than lead acid, and the cycle life is longer too. Hobby King has a decent price. A battery the size of a pack of cigerettes can do the job of a regular Pb-acid car battery. I plan to replace my car battery (using the appropriate battery management circuitry) with one soon.
ThomasK19 (author)2016-03-03
No way. Though these batteries can give a few amps it's by far too low to start your car. The cables you use look like 0.5 mm2. You need really thick ones for the amps to travel.
Mutt Man (author)ThomasK192016-03-03
The drill Battery puts out 14.4 Volts when fully charged and 12 amps.
Thats what the jumper leads have to carry , 12 AMPS !
1mm thick actually , but you can use thicker ones if you make this.
A starter motor has 2000 Watt or so. At 12 V that is around 170 Amps. So you will need 10 of you drill packs.
The Tinkering Penguin (author)2016-03-03
Did you actually try this out? Because I don't think this would work as the current given by the battery is way too low.
Unbelievable right ! I thought so too , until last weekend when I used this to Jump Start my Car.Tried and tested. Remember the flat car battery still has a lot of amps left in it,
About This Instructable
2,886views
29favorites
License:
More by Mutt Man:Jump Start Your Car With a Cordless DrillLithium Li-ion 18650  Multimeter
Add instructable to:
