3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Jump a Dead Car Battery
30 years experience as a mech ,my first concerns are safety .
ask questions ,your local mech will show details of what need to be checked .
boost boxes are a good way to start a dead car ,i included them as well as jumper start
Step 1Safety first
safety first
eye protection only pirates look good with eye patches
hand protection use latex gloves like medics do
electrical protection short piece of broom handle
Acid protection >Baking soda (I store it in a m&m mini tube remove M&M first )
13 comments
Nov 6, 2009. 11:28 AMwerewolf23 says:
This is a little bit incorrect: If you would do it in this order, you could put the black '-' cable directly to the '-' terminal of the battery as well.
The point of putting the black cable on a metal (grounded) part of the car (like the motor itself) instead of the '-' terminal is to avoid the battery from exploding or leaking acid:
First you connect the red '+' cable to the '+' terminal of the dead battery and THEN you connect the black '-' cable to a grounded metal part of the car. That way if there was a lightning (the arcing), sparks won't be near the battery itself. This way it's safer!!
Feb 7, 2010. 7:26 PMYerboogieman says:
I always knew to ground to the engine or something, but never knew why until now. Thanks.
Aug 25, 2008. 8:35 AMtedsmokeone says:
this is good for someone that needs to learn to jump start a car
Aug 19, 2008. 8:42 PMPunkguyta says:
This is a good instructable, however I'd reccomend that you label your pictures to include different tips. While It is a good idea to clamp the negative to the frame, that's also that much closer to the hundreds of electronics you're also trying to power whilst the car turns over. Unless the clamps are crap and can't secure a tight grip on the battery terminal, it shouldn't spark ever.
Jul 23, 2008. 1:03 PMgog says:
Glad to see your connecting to the frame and not to the battery of the car needing the jump. A lot of people try to jump through the dead battery despite the possibility for trouble.
Jul 23, 2008. 9:02 PMkarcinagin says:
Have never jumped using the clamp on the frame and it has always worked for me, dad, cousins, uncles. And the frame just get grounded to the battery. So way the frame?
Jul 23, 2008. 9:41 PMgog says:
You connect the negative clamp to the frame of the car being jumped as a last step so if it sparks it has less potential to ignite any possible gas buildup from the old battery.
Aug 19, 2008. 8:40 PMPunkguyta says:
How does someone have a 600amp alternator in their car? Even a big ford diesel can't be much more than 300 amps.
Jul 23, 2008. 5:25 PMNotn4 says:
People are way to dumb these days if theres actually a need for this instructable... it well done and all that but i don't see a point since i known how to jump start a car since i was 10 yrs old...
Jul 23, 2008. 11:47 AMGjdj3 says:
These are some good instructions on how to jump a battery and congrats on finishing your first instructable. The pictures are pretty good too. Just remember... capitalize and use punctuation!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:bikerbob2005
