In this instructable, I’ll show you how to construct a string of 30 lights (arranged in five groups of six) that you can power from a 16-volt wall wart transformer. Hook it up to a circuit of transistor drivers, and you’ll be able to make the lights bounce, chase and dance via sketches (programs) you’ve uploaded to your Arduino.
Above is a video of one set of lights doing a simple chase pattern. Keep in mind that you can make any other pattern by changing the Arduino sketch.
What You Need:
-- a string of LED lights, single or multi-color, about $5
-- around 50 feet of 18 or 24-gauge two-conductor speaker wire, about $10
-- six general-purpose NPN switching transistors, about $5
(I used 2N3904-type silicon transistors salvaged from an old amplifier)
-- six 4.7K resistors and six 180-ohm resistors, about $5
-- one 5.1v zener diode plus one 180-ohm, 1-watt resistor, about $2
(or use LM7805 voltage regulator to power the Arduino from the same source)
-- a breadboard or circuit board, heat-shrink tubing, a scrounged wall wart delivering at least 16v DC, and an Arduino
Tools: Soldering iron, solder, wire cutters and stripper, electrical tape. A multimeter is handy too.
Depending how fast you work (once you have all the materials), this project might take a long evening or a weekend. Ready? Let’s get started…
Remove these ads by
Signing UpStep 1
Got that nice new string of working LEDs handy? Get out your wire cutter and slice it up! Make a cut about halfway between each socket and the next one. If there are molded resistors in the string, remove them. Most strings consist of three wires: If you save the longest wire, you can use it later. When the cuttin’ is done, your pieces should look like this:
Now, you should have at least 30 bulbs in their sockets, with pigtails of wire attached. Go ahead and strip about 1/4 inch off the insulation on each wire. You’ll be connecting the lights shortly.
Add Comment
