Some of the items used:
1/4" Mdf
white spray paint
flat grey spray paint
skate wheels
tip of a Nerf dart
sand paper
dremel
hot glue
solder and iron
This is what will be used to power my K-9.
Dimension Engineering Sabretooth Dual 25A ESC
Dual 120w Scooter motors (Got two electric scooter off ebay and used all the parts to power K9, batteries, wheels, drive system and motors.)
Also to be added will be:
RF Transmitter to power all the extras
Powered antenna.
LED's for the top panel, and head and flasher circuit.
8" photo frame with sound playback.
Two 3" car speakers
Motor drive for tail and ears.
Remove these ads by
Signing UpStep 1The Start
I built the body and head out of 1/4 " MDF, mainly because it is light and very easy to work with. The whole complete build will not weigh that much so the 1/4" should be strong enough. I glued it all together with hot glue, very fast and very strong. I had decided that the top section of the body will be removable with all the electronics and drive motors fitted to the lower platform. This way working on the K9 will be very easy and I will not have to compromise the strength of the top section by cutting out pannels as doors. The very top panel in the body will also be removeable and fitted with all the switches and fuses. I also added an 8" cut out on the side you'll see why later.
It was hard to get the measurements for the inserts,on the sides,front and rear. so I played around until they kinda resembled the reference picture I was using. All the inserts were glued in place so that it would add to the top body strength. Accessing all the internals will be easy because the very top and lower sections will be removeable.
I WILL make one of these!
How completely cool!
I hvae been watching- and still am! How hot is Karen Gillan, and who doesn't love Alex Kingston?!- Dr. Who, for 40 years! I AM a "Whovian"!!
Your K-9 is GREAT!
K9 was one of my favorite things about the Tom Baker years.
EVERYONE VOTE FOR THIS IBLE FOR THE SPACE CONTEST.
I am sooooooooooo following u
Just amazing
could u use cardboard for the frame
Doctor Who: The Invisible Enemy
1977 NR 93 minutes
At the edge of the solar system, a mysterious virus infects the crew of an exploration ship. When Doctor Who (Tom Baker) arrives to investigate, the parasite turns him into the "Nucleus of the Swarm," a host for massive new proliferation. Racing against time, he miniaturizes clones of himself and Leela (Louise Jameson), and the two enter his body to confront the virus. Who's robot companion, K-9, makes his debut in this episode.
That should be what you need to look it up and watch it. Unfortunately not available on Streaming, but you can still get the disc. As an aside, many of the episodes were lost in the beginning, as they got taped over - the people borrowing them didn't realize there were no copies of them, and tape was really expensive back then, so they recorded over a lot of stuff . . . . very sad!
Only Mk. I was built by the director at the research institute. :)
great instructable idea
The prop continued to it's final appearance in "The Time Warrior" where K9 and Romana (II) remained in E-Space.
K9 Mk III turned up out of the blue at Sarah-Jane's residence claiming to be a gift from the Doctor in the pilot for "K9 and Friends" which did not proceed. That is why it is in Sarah-Jane's possession in the new episode "School Reunion" where it is destroyed and replaced with the Mk IV rebuild which appears in "The Sarah-Jane Adventures".
Yours is essentially the Mk III version because of the handle added at the top near the control panel, however you have omitted the handle which goes on the lower front of the body. Otherwise, an extremely well done version amongst the myriad copies that encircle the globe.
I've not seen it, but I understand that the animated version bears as little resemblance to the original as a Big Mac has to a Hamburger.
very good work with the rusty paint job too, i could never do that :P
