K'Nex Bolt-Action Rifle
13,645
10
146
Posted
Introduction: K'Nex Bolt-Action Rifle
An extremely powerful bolt-action gun. Holds up to twelve blue rods in the hopper. Most ideas taken from g12345389's sniper, and I thank him for that. Follow instructions carefully, or it won't work.
Step 1: Handle
Build as shown. Note the spacers at the top of the grip. You can either do this or replace those two with two grey connectors.
Step 2: Bolt/Firing Pin
Very simple. It slides on to the back of the barrel so that a grey rod goes through the holes in the grey connectors.
Step 3: Barrel...Part One
This is the back half of the barrel where the bolt slides in. Take of the yellow connector way in the back to slide it in. Those two black pieces at the end of the picture makes up the trigger.
Step 4: Barrel...Part Two
This is the tricky part. Build exacly as seen so the bullets load in properly. The pieces in front of the barrel are optional.
Step 5: Hopper
Easy to find out. Holds twelve blue rods.
Step 6: Stand (Optional)
Make these and slide them on to the connectors right behind the trigger.
Step 7: Put It Together!
Follow pictures in order. Hopper slides on to the white connectors up front.
Step 8: Lock and Load
Put rubber bands on like this.
To load, put as many blue rods you want in the hopper. If they don't load in straight, take a large rod to push the bullet in. Pull back the bolt. If you don't hear the bullet fall in, take a rod and push it into the barrel. the trigger locks in and...
Fire!
  • Minecraft Challenge 2018
  • Sew Warm Contest 2018
147 Comments
not bolt action but instead full function nice 5*
what are the black things betwen the gray yellow conectors
definetily not bolt action...but looks pretty kewl
1*
Turn it upside down, add a mag pusher, and a pump on the yellow connector attached to the ram and this could be pump action! :D
Not true bolt action....
could i use a black rod cuz they're stronger
For all firing pins, use black ones.
