Introduction: K'nex Bolt Launcher and Bolts
Picture of K'nex Bolt Launcher and Bolts
Disclaimer: This is not a toy. I am not liable for any injury, harm, or death caused by correct and/or incorrect usage of this weapon.
A very simple bolt launche that requires very few, common pieces and shoots a good distance (distance varies with rubber band strength and weight of bolt).
The pieces I list here are the bare minimum and most pieces can be interchanged with others in case you are short on pieces. Feel free to add more pieces to it to make it more fancy, elaborate, practcal, etc.
Pieces required for the launcher:
Rods:
2 orange/red
2 yellow
2 white
2 blue
2 green
2 grey/black
Connectors:
All connectors can be interchanged. What I list here is what I used in my version.
2 orange
4 green
1 white
Additional:
2 silver spacers/6 blue spacers/2 dark grey or black connectors and 2 blue spacers
1 tan clip connector/orange rail piece
Step 1: Building the Front and Middle.
Picture of Building the Front and Middle.
You will need:
Rods:
2 orange/red
2 green
1 white
2 black
Connectors:
1 orange
1 yellow
2 green
Step 2: Building the Back and Trigger System.
Picture of Building the Back and Trigger System.
Pieces needed:
Rods:
2 yellow
2 blue
1 white
Connectors:
1 white
1 orange
Additional:
Spacers with pieces
Orange rail piece thing/tan clip connector
Step 3: The Bolt
Picture of The Bolt
To tell you the truth, I have three different kinds of bolts. Unfortunately I will not show you how to make the other two kinds because (1)they are more complex, (2)they require a lot of hand/finger dexterity to build, and (3)one of them requires a material that you probably don't have access to and also requires a lot of hard labor to prepare it before it can be used as a bolt head.
This bolt is very simple, cheap, easy to build, and requires a few common household items:
3 toothpicks (preferably same size ones)
1 normal plastic bendy straw
For an instructable on how to build a better bolt, check out my Cheap Dart.
Step 4: Loading and Firing
Picture of Loading and Firing
The rubber band I used was approximately 1 7/8 inches in diameter, 1/16 inch thick, 1/8 inch wide, and has a circumference of about 6 6/16 inches.
To prepare to load, place the rubber band around the orange/red pieces in front and pull it back until it fits on the orange rail piece thing/tan clip connector on the trigger.
To load, fit the back of the bolt into the rubber band at the back snuggly so that it doesn't drop and place the tip of the bolt onto the rubber band around the orange/red pieces in the front.
To fire, simply place one hand under the green connectors in the front and around the black/grey rods. Place your other hand around the yellow rods in the back and pull the trigger (blue rod).
Spycrab (author)2010-05-05
huh, sweetness! :D
al9595 (author)2009-09-10
can we use grey instead of black?
globe (author)2008-10-25
can the ram penetrate cardboard
altaria1993 (author)2007-07-24
nice, though, in the front you should put the rubber band UNDER the yellow/orange connactor, or you will get a hock of a lot more friction, wich you probably don't want ;) alty
xiao hawk (author)altaria19932007-07-24
The reason that I put the rubber band over the yellow/orange connector in the front was so that it wouldn't be necessary to go retrieve the rubber band or bring out a new one each time I have to fire. If it was under the connector, it would drop each time and I would have to waste time bending down, getting it, placing it back onto the gun, then pull it back before I can load another bolt. If it was over, all I needed to do after firing a shot is to pull the rubber band back and load another bolt. Much simpler, no?
NinJa_RaiZer (author)xiao hawk2008-10-23
duct tape or bind the band onto the frame to solve it
bradleyJOHN (author)2007-11-23
ARE YOU CRAZY
xiao hawk (author)bradleyJOHN2007-12-12
I'm sorry?
e-hizzle (author)2007-08-03
xaio hawk, could you please post the other bolt i dea even if it is more complicated?
xiao hawk (author)e-hizzle2007-08-04
Sure, just go to the making the bolts section and there should be a link to it.
xiao hawk (author)2007-07-30
Does anyone want me to post my mangonel/onager? I built it recently and it works pretty well. It launches marbles, which is a very common and cheap ammunition though I think many other things can be used as ammo too.
Metal4God (author)2007-07-20
first comment yipee
xiao hawk (author)Metal4God2007-07-28
I would also like to know if this is what you do to every instructable you find with no comments yet.
xiao hawk (author)Metal4God2007-07-20
Can I have something more "constructive" as they put it?
if you stabilised the frame it would be alot better (constructive comment) :P
I could, and I would, but as I have said before, I like to keep mine as light as necessary. If you wish to do so, feel free to.
knexguy (author)2007-07-20
lokks kind of original... in an interesting way. good instructable. not so sure about the gun.
xiao hawk (author)knexguy2007-07-20
I'm not so sure whether that's a positive or negative comment...
knexguy (author)xiao hawk2007-07-21
it definately positive now ive built it. fires well and accurately. good trigger design!
Rage (author)2007-07-20
interesting idea, and good trigger, but you might like to make it look better, or more like a gun or crossbow
xiao hawk (author)Rage2007-07-20
That's the reason I wrote "Feel free to add more pieces to it to make it more fancy, elaborate, practcal, etc." I like to keep mine as light as necessary. My current one has about 8 bolt holds.
Rage (author)xiao hawk2007-07-20
yeah, i didn't see that, however it might get a higher rating or viewing number if it looked cooler
crestind (author)2007-07-20
Unique trigger design!
xiao hawk (author)crestind2007-07-20
Here's a note I should have put in the instructable about the trigger: When aiming at something relatively close (10, 20 feet), note that the bolt will shoot slightly upwards because the rubber band refuses to let go of the orange rail piece thingy until you have pulled the trigger some distance. When aiming at something this close, you may want to aim slightly below the place you want to hit.
Whaleman (author)2007-07-20
cool, new, and not a copy of 80% of the other knex instructables
About This Instructable
1,714views
0favorites
License:
More by xiao hawk:K'nex Semi-Automatic/Repeater/ShotgunKnex Grenade8-sided Paper Shuriken
Add instructable to:
