K'nex FN2000
7,060
15
268
Posted
Introduction: K'nex FN2000
This is a Rubber Band Gun that is loosely based off of the Belgian FN2000, below are two pictures. One is a real FN2000, the other is my K'nex one. It is an 8-round cog-driven RBG, it can fire about 30ft max., (better than most of the rod firing guns on this site) and accurately at 20ft indoors. I recommend that you use #16 rubber bands mainly because they are the only ones that I have that are suitable. Please comment, rate, and tell me about any mods or improvements on the gun or if there is a part of the instructable that you do not understand (no not do any of the previously mentioned actions if all you are going to do is badmouth K'nex in general).
Danke und gute Nacht,
You.
Step 1: The Frame and Trigger.
This is the frame, which you might have guessed from the title of this step.
Picture 1: This will be the right side of the frame.
Pictures 2-5: Close-ups of the right side of the frame.
Picture 6: Grab these, they will hold the mechanism later.
Picture 7: Put the pieces here.
Picture 8: Put two spacers on the upper piece.
Picture 9: Add the cog and two more spacers.
Picture 10: Make the trigger.
Picture 11: Be sure you do not add green rods on the sides.
Picture 12: Now slide it on to the blue rod (The blue rod will be slid into the half circle). Be sure that you put green rods into the holes.
Picture 13: Add two rods to these spots and add a rubber band to the rods.
Picture 14: The left side.
Pictures 14-17 : Eh, close-ups of the left side. Exactly the same as the right side, but without the orange rods sticking up.
Pictures 18-23: Clamp the two sides together.
Picture 24: Now add a spacer and a connector to each blue rod.
Yay, it is almost done.
Step 2: The "Barrel"
This is the "barrel", it is for hooking the rubber bands on.
Just follow the pictures and attach it as shown.
To load, you hook the rubber band on to the barrel, then to the cog, then pull back on the cog. Repeat until you have attached 8 rubber bands. Pull the trigger to fire.
  • Minecraft Challenge 2018
  • Sew Warm Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
274 Comments
it lacks a mag.
bu otherwise it is pretty much the same
an educated life, in which he can speak english.
And you have a loose grasp of the English language.
Well, good sir, put into that context, it does seem reasonable to assume that the ice has gone rotten. After all, this pie weather has caused a certain set of headphones take flight. Highly unreasonable, I agree, for the aeroplanes are all over the place and not a single one has roasted tissues, for the paper tells me so. In conclusion, we must stop the Decepticon, else on the Santa Maria the waffle cones will revolt against the kindhearted ligers of this fine establishment.
What doesn't fit where? I don't know what you're referring to.
 wait is this semi-auto?
Shoots one rubber band with each pull of the trigger.
