Introduction: K'nex XBow
Picture of K'nex XBow
My k'nex xbow, a powerful gun with good range, and, it has a true tirgger that should be able to take almost any power of rubber bands you have. I have made sure this version doesn't use any exotic pieces. Hope you enjoy!
Step 1: Making the Handle
Picture of Making the Handle
First we've got to start with the handle, the rest of the trigger system will build up around this.
Pic:
1. Build one of these
2. And one of these
3. A piccy of the two bits you should have just made
4. Build one of these (blue rod with 5 greys)
5. Finished handle
Step 2: The Cage
Picture of The Cage
The cage kinda holds together the trigger and the leasing mechanism, its simple to make just make sure you 'cross brace' it with the little white pieces as pictured.
Pics:
1. Start with this, all of those hard to see pieces are the purple 90 degree connectors
2. This is what it (pic 1) looks like from the side, make sure you use the blue connector on the purple for one of them. (both close and the far side)
3. Make one of these
4. Add (pic3) onto the end of the piece you just made to get this:
Step 3: Trigger
Picture of Trigger
This is where the trigger starts. The trigger uses a ratchet like system which is incredibly strong and will allow you to put extremem weight on it whilst still being able to loose the bow.
Pics:
1. make one of these
2. add 2 white pieces (this will make the trigger, the reason i don't have a white bar on one is because i use this gun in my right hand so this makes more sense and is more comfortable)
3. get this piece ready
4. Clip it onto the piece you just made(pic1+2) so that the grey pieces can hang freely
5. clip two red rods onto the free hanging grey clips you just put on
6. Make one of these (add another white rod where the other two were, sorry, forgot to put this in when i was rebuilding)
7. clip both pieces together and add a blue axel rod through the second bit we made
8. should look like this
9. line up step 2 with the new bit
10. shoule look like this, the bits should freely move
11. when this is at this angle......
12. .......this should be at this angle
Step 4: Attach the Handle
Picture of Attach the Handle
Just a quick step, attach the handle to the trigger.
Pics:
1. add two blue (360 conectors) onto the front
2. clip the handle on (step1)
Step 5: Building Up the Body
Picture of Building Up the Body
Gotta make this baby strong.
Pics:
1. 2x of these
2. add both to back of gun
3. Should look like this from the top (add those grey to space apart the whites, sorry forgot about photographing this step earlier)
4. make this (the rathchet)
5. make this
6. clip (pic5) to (pic4) so you get this, its strong!
7. Should look like this
8. insert the new piece in, make sure it is to the right of the white rods we made earlier
9. looks like this
10. make this side bit x 2
11. add them together to get this structure
12. should look like this from the side
13. line up both bits
14. connect, now very strong
15. attach rubber bands like so to both sides
16. will look like this, pulling the trigger will release the ratchet
17. change the top bits from the 360 ones to the flat top ones, sorry about this forgot when i was rebuilding!
18. now looks like this
Step 6: The Front
Picture of The Front
Building the main front of the bow...we're nearly finished...
Pics:
1. build this
2. add some greens (love those little guys)
3. clip this on both sides
4. this white is important, put one on both
5. sorry this is soo hard to see, it basically clips ontop of the middle channel thats on pic1 and 2
6. clip it on
7. start adding the top, should be pretty self explanatory
8. nearly done
9. clip it all on to the trigger section
Step 7: Loading and Firing!
Picture of Loading and Firing!
Get ready, here it comes!
Pics:
1. make a rubber band like this, just string to tie tow together (the string tends to lock in better to the ratchet trigger mechanism) the more band the more power, mine has 2 per side.
2. hook one side of bands on
3. same to other side
4. to load..... pull back the string
5. push this part of the ratchet (very back of the gun) downwards as far as it'll go
6. pull sting back to the ratchet and hook it over all three white clips
7. like this
8. a bolt, build many of these, try varied sizes of rods, tell us what works best!
9. push the bolt back into the string
10. your done, point away from youself and pull the trigger!
thanks for reading, this is my first instructable i hope you enjoyed!
if u made the gun please post pics i wanna see!!!
nicky123 (author)2010-02-04
its a killer weapon!?!
LOL LOL LOL
mrbox (author)2008-11-06
By far this is the best actual crossbow, not a cannon sized or large crossbow ive made mostly because of its simple yet reliable design of both the trigger and the body =) I just haven't found a good bullet that doesnt twirl after 30 feet, i can pierce cardboard and break .5in plywood at 10-20 with your normal bullet but thats only when i add a ton of rubberbands to make it goes straight, im trying to make a good bullet for it but i can't seem to make a good one...
An Villain (author)mrbox2009-07-25
fletch it like killerk magnum round.
101man (author)2009-07-11
i built it its AMAZING
yerjoking (author)2008-09-30
Hey can I borrow your trigger mech?
Zenosythe (author)2008-04-26
This is, in my opinion, the best knex thing on this site! as for the bolts, heres of picture of my preferred design. I haven't tested it with all 3 grey rods on, but with 2 it went a fair distance for the size of the bolt. here's a picture of my completed one and my knex weapons, all of which are on this site, and none of which are built by me :), though I have modded them all.
Oompa-Loompa (author)Zenosythe2008-09-14
where's mine??? LoL jk. you have too many parts
net pirate (author)Zenosythe2008-07-06
yeah your idea is probably better than mine
Abominatus (author)2008-01-21
NICE GUN/CROSSBOW........ IM SAD THOUGH CAUSE IT BROKE 1 OF MY ORANGE CONNECTERS
I_am_Canadian (author)Abominatus2008-03-13
DONT TALK IN CAPITALS ALL THE TIME PLZ.
Abominatus (author)I_am_Canadian2008-04-21
WHY?
I_am_Canadian (author)Abominatus2008-04-21
ITS REALLY REALLY ANNOYING THATS WHY
Abominatus (author)I_am_Canadian2008-04-25
I AM SORRY BUT I FAIL TO SEE HOW IT CAN BE ANNOYING.........
I_am_Canadian (author)Abominatus2008-05-21
OH REALLY...... WELL, IT IS. IT JUST IS. OK?
Abominatus (author)I_am_Canadian2008-05-22
GIVE ME A PROPER REASON AND I WILL CONSIDER IT.
I_am_Canadian (author)Abominatus2008-05-22
WELL, IT REALLY STANDS OUT FROM ALL THE OTHER TEXT, WHICH ALSO MEANS THAT IS DISTRACTING. ALSO, YOU CANNOT USE CAPITALS TO EMPHISISE WORDS, BECAUSE YOU ARE EMPHESISING THEM ALL. ALSO, YOU GET INVOLVED IN ANNOYING CONVERSATIONS LIKE THIS ONE.
net pirate (author)I_am_Canadian2008-05-29
will you two just give it a rest?
I_am_Canadian (author)net pirate2008-06-11
Okey Dokey
MaYbE THIS Is An IdEa!
NOOOO!!!!!
net pirate (author)I_am_Canadian2008-07-12
Hey i like that idea it works for you and kill-bot 1!
I_am_Canadian (author)net pirate2008-07-19
I do not
lol your saying to not type with caps yet your doing the same thing lol :)
I know. Just for that conversation, to show him how annoying it is.
I3uckwheat (author)2008-07-07
this rocks right coz
buck2038 (author)2008-07-07
I added a stock to the back of the gun.
yay i got an image!
I put tape over the top surface because I was having problems with the string catching on the pieces. It hepled smooth the surface so the string would not catch. Overall that was they only problem. Hey Gamer-X(CUZ)
hi big coz
WEBCAM
i ment 2038 and i ment wepcam sry
buck3038 is my cousin on msn webam he showed me that he put tape over it so it wouldn't catch
One question, how do you get the bullet to not spin when fired? Both types of bullets spin when fired.
This thing is awesome!! It is very powerful!!
net pirate (author)2008-07-06
yeah have any of you got any ideas on how to mod this thing?
grassy123 (author)2008-06-27
love the crossbow very powerful is there any way u can possibly upgrade it with lke scope or sum10 like that
joey2542667 (author)2008-06-14
woah this is awesome!!!!! the only thing is the bolts, they tend to spin in midair. I looked at and tried all the designs on the comments exceptthe one that wouldn't be possible... so if you could make a better bolt that would be great!
!revenge! (author)2008-03-22
SHUT UP
drummer ian (author)!revenge!2008-03-22
excuse me?
!revenge! (author)drummer ian2008-03-27
they are talking in capitals all the time and i'm freakin out
apples!!!!! (author)!revenge!2008-05-07
talk about ocd....
Storm950 (author)2008-04-30
I have made it twice now, 2nd time I had these really stretchy and powerful elastics, I did what you did with the string and added 4 elastics, 2 each side. My Dad said it was around a 15 pound pull lol, getting close to a small pistol crossbow, one problem. When it has too much tension the white connectors on the ratchet start to crush in on one another thus making the bolt very difficult to insert and probably increasing friction when it fires. You don't have to help because I destrroyed it a long time ago and am currently buidling the reaper :P
apples!!!!! (author)Storm9502008-05-05
the reaper is freakin awesome
apples!!!!! (author)apples!!!!!2008-05-05
so is this tho
drummer ian (author)apples!!!!!2008-05-06
why thank you
apples!!!!! (author)drummer ian2008-05-07
this can also be an rbg which is cool very good instructions, +1
any idea how many 3d connectors are used?
Storm950 (author)apples!!!!!2008-05-06
I am not buidling the reaper any more though because well errr it was too tedious I suppose... Gonna build DSman's new compact AST.
apples!!!!! (author)Storm9502008-05-06
lol i am building it too
net pirate (author)2008-04-17
I used 8 elastic bands (4 on each side) and i was blowing small holes in cardboard... these arrows work best:
About This Instructable
6,986views
26favorites
License:
More by drummer ian:Electronics Projects: Constant Current Power Supply using Pulse Width ModulationK'nex XBow
Add instructable to:
